The pads with the ears on them look right. The "earless" one is definitely wrong for a 540i. Who'd you order your gear from?
540's have bigger brakes than other E34 cars (except M5). Pads are not interchangeable with other models.
Hi all,
I ordered some brake parts for my 1995 540i E34 M60.
My mechanic tells me the rotors and pads are not the right ones for my car. I checked with the supply store and they tell me they are the right items. Does anyone here recognize these pads. I think maybe the previous owner may have modified the braking system.
'95 540iA ~212k
The squarish pad on the left of your picture looks like the pads that go with the 4-pot "Nurburgring" calipers that were standard on the late euro M5 and Canadian M540i. The pad with the ears looks like a stock E34 pad. Although the "regular" 540i uses a different rotor, the pads are interchangeable with most other E34s (525i, 535i, 530i and US M5).
Post a pic of your caliper, and we'll know better what you're dealing with.
Originally Posted by ceasarco
Drew Z
Formerly 540iT/6, now . . . 3, 5, 7
Hey, thanks for all your help. My 540 is a Canadian model. I purchased these parts locally from a London Ontario brake supplier and the rotors from a Connecticut supplier. I don't have any pics now of the caliper but I am posting pics of the rotors. I will try to get pics of the calipers from my mechanic.Originally Posted by DrewZ
left rotor looks cracked
would be sweet if he has an m540i. post up a pic of your car and one of the calipers and we'll go from there.
are my eyes playing tricks on me or is the right rotor a floating rotor from the M540 and the left rotors a normal one? Pretty sure you have mismatched rotors.......now you NEED to post pics of your calipers before going further.....
Its on a hoist at my mechanics garage. I 'll try to get over there tomorrow and gets some pics.Originally Posted by angrypancake
Thanks again
left rotor is rear 328mm rotor and right rotor is front 345mm rotor. Similarly, top pad pic is front pads and bottom pad pic is rear pads.
Originally Posted by Scott H
Drew Z
Hi, I'm going to my mechanics this afternoon and take some pics of the calipers. He tells me now that these are 4 piston calipers that are in good shape and that the rotors can be machined and saved also. If these are the 4 pot Nurburging calipers where can I buy the pads for them.Originally Posted by DrewZ
Thanks I will be back with pics and any part numbers I can retrieve.
