If your heater core has a leak, then your coolant will be running down from deep behind the dashboard, down the carpet an onto the front footwell metalwork. You may be able to smell coolant too.
HTH,
Shaun
I have the infamous heater core problem, and my coolant level needs topping up from time to time.
I realize that coolant is getting on/in the heater core, but then where does it go? I'm not really familliar with all the ins and outs of the cooling system and the heater core. When my coolant level goes down, where did the coolant go?
HTH,
Shaun
if your expansion tank is mounted to the firewall i would start there. I had a small crack in mine and would loose a little collant over time. New tank, no more coolant leak. Another way to tell if your tank is leaking is to remove it and look on top of the bell housing. if you see tell tale signs then i would assume its the tank. The tanks are prone to develope cracks on the back side of the tank.
I was loosing coolant only when my heater is ON. So today when I mover my car out of parking lot I saw some fluid on floor under the engine bay. I opened hood and checked while engine is running and heater set to full hot. I found some wet spot under intake mainfold. Got a flash liget and zoomed it on different spot under intake mailfold and find coolant seeping from a tiny crack about an inch away from the clamp which connects hose # 7 to engine block. So I think I need to replace hose # 7 ( 4-way hose). But until then I am planing to turn OFF heater (set to min). But I am not sure turning heater off will make leak stop or not. Any idea?
http://www.realoem.com/bmw/showparts...23&hg=11&fg=35
You might wanna check under intake mainfold for any leak related to heater before you go for extensive check in heater core ect.
Akhil
What makes your think it's the heater core? Coolant leak may be a number of things. Are you sure it's not pooling somewhere inside the engine bay?
isnt there a tray under the heater core that drains to the outside?
Gone but not forgotten
Yes there is. If the core is leaking it drips down to the "box" that its in (for lack of a better word). There is a drain tube there that goes to the outside. This is there also to prevent condensation from building up in that area. You can put the car on ramps, find the hole and stick your finger in. It will be obvious if its coolant or not. You can even take a small taste (be careful, it is poisonous) if you aren't sure.
