I'd say you have ice in your fuel and you need some gas line de-icer.
Use an isopropanol based gas line de-icer as it mixes with the water and allows it to be burned off. Methyl alcohol will work but won't allow the alcohol/water mix to burn off as it doesn't mix with the fuel in the same way.
Always keep your tank better than 1/2 full whenever the weather is cold to minimize moisture problems from condensation.
Good luck.
