I'm not Bill R but I saw him on television once.
bump
the fuel pump relay in an Acura 3.5RL 1997?
Javier
PS: Got the Odissey, think you made a great suggestion, will PM pictures and coments ASAP.
bump
If it ever helps some one else, it is located under the dash to the right of the steering column. It is a black box with two connecting plugs, towards the center of the car is, at its side, a white box that is supposed to be for the steering column adjust, and finally a metal cased box for cruise control (this last is labeled properly).
The black box includes the DME relay and the pump relay, relays are soldered on a circuit board with 3 diodes an a resistor. My problem was a broken (cold) soldering point in the pump relay power contact (as usual).
Javier
