Thread: @%#!$%@#$%. Radio / iPod works like a charm ...
    Dec 2005
    Nashville, TN
    Default @%#!$%@#$%. Radio / iPod works like a charm ...
    (see here) ... but I've blown out the bulb on my OBC. Rassafrassa.
    So, is there any way to get at it without taking apart my dash again?
    1995 525iM - 131k - Alternator play, broken s-belt
    1995 525iA - 147k - Tensioner weirdness, broken s-belt
    2001 Intgra GS-R - 130k - spun bearing
    2002 Honda Odyssey - 80k - fragged transmission
    Aug 2005
    Toronto
    Changing the OBC bulb is way easy.
    Slide out your radio. No need to unplug it. Just slide it out.
    Pull the lever to eject the OBC.
    Drop in a new bulb.
    Repeat in reverse.
    Whole thing takes five minutes, max.
    Please post pics of the radio in situ, and let us know if you find the 700MB limit, um, limiting.
    Jay Lebo - Toronto, Canada
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    Sachs Suspension Kit
    E.A.T. Chip
    Aug 2004
    Southern New Hampshire
    If the lever for the OBC is accessible from the opposite side of the radio and you had as much fun as i did trying to get the radio in place with all of the wiring, it may be easier to take out the glove box and take down the side panels to get to the OBC.
    Dec 2005
    Nashville, TN
    Fabuloso. All I need to do now is identify the eject mechanism. Photo / schematic, anyone? I'll post pics soon. And I haven't really hit any major pains in the butt vis a vis playlists, but ohhhhhh lord, it scrolls through artist names slowly. Course, I haven't read the manual yet; maybe I'm doing something wrong.
    Aug 2005
    Toronto
    Quote Originally Posted by ProZak
    Please keep us posted about that scolling issue, and other issues you discover with the unit. I'm really curious as to how well it all works, with the iPod.
    Now, for the OBC...
    Slide out the radio and rest it on the center console, wires still intact.
    At the back of the OBC, on the left side (LHD car -- dunno about RHD), near the top of the OBC, there's a little tab at the back. It's a lever, in fact, but doesn't look like one. You'll only see the tip of it, which is a little metal tab.
    Get your finger behind the tab and pull hard directly towards you. That is, pull straight out. The lever's arc is practically a straight line, so pull straight out.
    If you've never done this before it might take a lot of effort.
    Be ready to catch the OBC, as, if you're applying a lot of effort, it will eventually shoot out of the dash at Mach 2.
    There are three little light bulbs in the OBC, each accessible without any disassembly. Each one takes a 90-degree turn to remove or replace. Replacement bulbs are about $2 at the dealer.
    To get the OBC back in, I found it's a good idea to put equal pressure on the face of the OBC and on the lever. If you put all your effort on the lever, the face of the OBC can get snagged on the dashboard and potentially break.
    Hope that helps!
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    E.A.T. Chip
    Dec 2005
    Nashville, TN
    Awesome instructions, my man. I'll get right on that this weekend. Oh, and pics of new stereo in this thread; comprehensive review coming later.
  1. Ipod instead of CD changer on stock radio
    By Cambridge in forum 5 Series BMW
    Last Post: 01-11-2007, 10:00 PM
  2. Radio only works in hot weather
    By Astrom33 in forum 3 Series BMW
    Last Post: 08-26-2006, 08:29 PM
  3. IPOD nano Your BMW
    By mzarifkar in forum 5 Series BMW
    Last Post: 01-24-2006, 12:37 AM
  4. ipod mounting
    Last Post: 01-05-2006, 03:48 PM
  5. factory radio is dead...what works with the changer?
    By RIPN RAY in forum 5 Series BMW
    Last Post: 12-30-2004, 12:17 AM
