Originally Posted by Jeff N.
This Potenza tire redefines ultra-high performance. With the evolution of UNI-T® and UNI-T AQ™ to UNI-T AQII, the Potenza S-03 Pole Position reaches the peak of performance in both wet and dry conditions. And, it keeps performance up as the tread wears down. Engineers have also reduced the noise factor in new and worn stages. Driving enthusiasts will admire the unique tread and sidewall design inspired by the Bridgestone Potenza racing rain tire.
Innovative Tire Design - A Comprehensive Tire Design Method
This method improves handling in wet or dry conditions and reduces irregular treadwear by combining the ideal tread design, casing shape, materials and construction.
Innovative Roundness - Rounder Is Better
Rounder overall tire shape provides better balance for wet or dry handling.
Innovative Compound - Longer Is Stronger
L.L. Carbon utilizes a special form of molecular re-engineered carbon black, a key factor in improving tire wear while enhancing wet performance.
Super EPC
Super EPC consists of advanced technologies, an Anti-Hardening Resin and Link Stabilizing Agent, to counteract the effects of heat so worn tires have the flexibility needed for wet performance.
Dual Layer Tread
As the tire wears, more of the inner tread is exposed so the tire continues to grip the road in wet conditions.
Particle Z
A compound additive that works in tandem with base and top compounds and improves tire flexibility to enhance wet performance.
Hydro Evacuation Surface (H.E.S.)
H.E.S. more efficiently channels water away from the tread, reduces the risk of hydroplaning, and leads to better wet performance.
Super EPO
Super EPO goes beyond EPO in improving wet handling as the tire wears. The interactive elements are Super EPC and an enhanced version of Dual Layer Tread.
Consistent Surface Contact (C.S.C)
C.S.C, a pattern of tread blocks designed for uniform contact pressure, improves dry and wet handling, reduces irregular wear, and results in better ride comfort.
Warranty Summary:
Platinum Pact Limited Warranty
30-Day Test Drive
Standard Limited Warranty
