I have both the e34 and e30 and no they are not the same.The e34 mount is 6 times more expensive here in Malaysia.Originally Posted by BigKriss
ETK says the e34 strut mounts don't go on other models but I emailed notlec and they say they are the same? Do you guys know?
I'm being quoted aus$400 (for the pair) for clubsport adjustables.
have you bought much stuff from noltec? I was thinking of purchasing some urethane thrust arms for my e28 from them (and e34 control arms )Originally Posted by BigKriss
I haven't bought anything yet Rob, but the guys over at eurocca.net are saying that the gear is better than what K-Mac offers (not on the e34 though). I thought on the e28, that e34 thrust arms are a direct swap. Have a look at ace-e28's setup. He's done all the work. I also found out that the "grunts" polyurethane bushings are from noltec also.Originally Posted by rob101
edit - I e-mailed notletc saying that the strut mounts would be different, I'll tell you what they say.
Kmac product quality has never been great, so I'm told.
Kristian, did you get my email, BTW?
best, whit
yeah to my knowledge the control arm is a direct swap but not the thrust arm, ace's setup uses (like alot of people in the US) noltec bushes on the e28 thrust arms and e34 control arms.Originally Posted by BigKriss
Ace has done alot of work on his e28s, i wonder if he'll ever get an e34. He'd probably make a site to rival e34.net
Yea nice site. Kriss, I am pretty sure the K-Mac adjustable upper front shock mounts fit e34.... Nick. BTW; I'm going to make a subframe removal tool soon- just for funOriginally Posted by rob101
Some E34 applications are common to the E30 type and both use the same upper spring pads. Main difference is single path vs. dual path design. E34 typical design has separate isolators for the strut rod and spring which de-couples the spring force from the damper mount allowing some compliance. E30 single path types have the spring and damper attached to the same point which can make it harsher since the isolator carries the weight of the car and must be stiffer.
Before laying out $$$$$ for these parts, maybe a trip to a boneyard is in order ($) for comparison. Keep in mind there was a damper change midway in E34 from 12 to 14mm upper threads - this could complicate your project.
Anthony
03/64 production
I would be intrested on how that goes for you... I have been looking at making one also...Originally Posted by genphreak
I miss my e34
