Headlight Cracked Lens
I've got a cracked headlight lens in my 1992 535. For some reason I don't have elipsoid headlights and they are not sealed beam either. Have not yet done the research on exactly what I have but I do have a cracked lens.
I took my dremel tool and cut into the entire course of the crack. About 1/32 inch or so. Then I taped it off close to the crack and filled with acrylic fingernail polish (I used clear, you can chose your own color =).
As soon as it drys, I'm going to buff it out a little bit and then cover the headlights with the stick on clear vinyl covering that I bought in sheets a couple years ago. Although it might not be the preferred method, it is a lot cheaper than changing the lens and with the covering over the headlights, I won't be breaking any more lenses.
Nothing to lose.
Mike Holbrook
Meridian, Idaho
