Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Malfunctioning temp guage
    Aug 2005
    Toronto
    Default Malfunctioning temp guage
    The coolant temp guage on my dashboard seems to be on the fritz these last couple of days.
    It will sometimes dip into the blue zone, or hover somewhere in the left-half of the dial when I know the engine is up to temp (HVAC air is very warm).
    The needle will periodically hit its usual mark (i.e. vertical), but not stay there.
    Since the air coming out of the vents is always very warm, I suspect a problem with the sensor rather than an overcooling problem with the engine.
    Any advice?
    Jay Lebo - Toronto, Canada
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    Sachs Suspension Kit
    E.A.T. Chip
    Bethlehem, PA
    Funky capacitors in the instrument cluster can do this, and your car is plenty old enough for the caps to be bad. Is anything else on the cluster acting up now and then? If you've already eliminated this, it might be a bad connection, however bad connections would more likely cause high readings. It wouldn't hurt to re-seat the connectors on the sender.
    Aug 2005
    Toronto
    Quote Originally Posted by SRR2
    Everything else works fine.
    Where is the sender? I also suspect a loose connection somewhere, since the problem is intermittent. When the needle does move, it moves very briskly, leading me to think there's an electrical connection somewhere that's loose and is getting disconnected and reconnected periodically.
    Funny how the needle never moves right of center. The malfunction seems to always send the needle to the left -- never the right. Does that mean anything?
    Thanks.
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    E.A.T. Chip
    Boston & Attleboro MA
    Usually on an issue like this, many suggest to check all the ground connections on the car. About 1/2 the time its a bad ground.
    Current
    2008 M5 6 Spd
    2000 Z3 2.8 5 Spd MSport
    2012 X5 35d Sport
    1995 540i 6 Spd
    1992 535i 5 Spd
    Former
    1995 530iA
    1986 635CSI 5 Spd
    2011 X3 2.8 MSport
    Aug 2005
    Toronto
    Quote Originally Posted by DaCan23
    How do I do that?
    Please excuse my ignorance. I even amaze myself at how I manage to know so much about cars and so little about working on them. I guess that what comes from getting all your knowledge from reading rather than from getting greasy.
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    E.A.T. Chip
    I cant say I am a pro at inspecting grounds, nor do I know the 4-6 grounding spots on the E34 outside of the hood, alternator, & battery. But at the connections look for corrosion, clean them w/ wire brush, and/or buy & attach new grounding cable if needed.
    Quote Originally Posted by Jay 535i
    How do I do that?
    Current
    2008 M5 6 Spd
    2012 X5 35d Sport
    1995 540i 6 Spd
    1992 535i 5 Spd
    Former
    1995 530iA
    1986 635CSI 5 Spd
    2011 X3 2.8 MSport
    Wellington,New Zealand
    when my temp guage was doing this i cured it by simply unplugging and replugging the connectors a few times!
    Gone but not forgotten
    Aug 2005
    Toronto
    Quote Originally Posted by Paul in NZ
    How, please.
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    E.A.T. Chip
    Bethlehem, PA
    Jay, you need to buy yourself the Bentley book for your car. I'd be happy to help you out, but I don't have mine any more. Someone here should be able to tell you where the sending unit is. I think it's on the lower left side of the engine, but honestly I don't remember that clearly.
    As far as grounding goes, you could spend a half lifetime chasing down all possible grounding points, but it's true that one critical bad one can screw things up pretty badly. I'd go after the sender first. Even though it's a PITA, you might try reseating all the connectors on the back of the cluster. That would be a good time to put in new lamps for the odo, cc, and trans annunciators.
    Default The two coolant temp sensor on M30 are up
    on the t-stat housing, right behind the fan. Sounds like intermittant or poor connection.
    http://www.realoem.com/bmw/showparts...18&hg=11&fg=35
    How, please.
  1. Cassette deck malfunctioning?
    Last Post: 05-12-2007, 11:44 AM
  2. Oil Temp/Press & Water Temp Gauge Install
    Last Post: 06-26-2006, 01:25 PM
  3. alarming noise and no gas, temp, readout guage
    By djapro in forum 5 Series BMW
    Last Post: 05-08-2006, 03:55 AM
  4. Replies: 16
    Last Post: 12-02-2005, 08:20 AM
  5. 1990 525i temp guage went hot then clunking noises started
    Last Post: 03-24-2004, 08:29 AM
