if you cant tell how it was bolted then you dont have much of a choice here, you have a 33% chance of "guessing" correctly
How important is it to retain the alignment of the pressure plate to flywheel when re-assembling? As I was anticipating replacing the clutch and pressure plate, but then realized the old bits had lots of life left, I didn’t mark the alignment of the pressure plate to flywheel as Bentley suggests.
As there is no noticeable runout on the clutch, and very little wear on the pressure plate, should I worry?
Thanks again,
Dave M
I'll get my monkey (primate) to pick a spot, or, for more fun, maybe I'll ask my wife to help.Originally Posted by 632 Regal
Dave M
maybe if you look real closely you might see some markings that match the mating surfaces? I dont think it's that important tho if you cant.
You don't have an alignment tool? (looks like a little dildo)
This is not a BMW one, but the BMW one looks similar
Yep, I have the dildo, I'm concerned with placing the pressure plate back on the flywheel in the same position (Bentley suggests this). As in marking the driveshaft so its stays aligned with the output shaft on re-assembly.Originally Posted by Scott H
Any thoughts?
Dave M
I have always done it that way
Originally Posted by Dave M
damn, having one of those "dildo" things whould have saved me the trouble of manufacturing one form a piece of wood on my mini lathe...
Don't worry about it. The main reason match-marking is recommended is to rule out the cause of any new vibrations that show up after reassembly. I think its more important on the driveshaft, but I've never had a problem on occasions when I forgot.
Paul Shovestul
Thanks again Paul,Originally Posted by Bellicose Right Winger
I couldn't find any tell-tale marks on the clutch or pressure plate, so I just 'spun the wheel' and assembled it. I don't think I'll lose any sleep
The engine is well enough to be dropped in when the mood hits me, so i'll be back with more questions soon enough.
Dave M
