Maybe being on the brakes loads up the steering system, increasing the effort required of the pump?Originally Posted by Moigy
Just a guess.
Hi, I purchased a 92 530i M60 with 120,000 about 8 months ago. Great motor and absolute bargain... until about 3 weeks ago it started making a slight grinding noise when I turned the steering tightly.
I took it to a garage and the mechy told me it was the water pump bearing. I questioned this and he assured me that the strain from the power steering pump on the belt to the water pump was causing the noise. I replaced the water pump and thought it was sorted as the old bearing was shot. Unfortunately it was still making the noise!!! It has gotten so bad now that the grinding noise is happening whenever I turn the steering wheel and even when braking???
I was thinking power steering pump but why would the grinding get worse by applying the brakes?
Any help appreciated
I've heard the steering pumps a hell of job and expensive, is this true?
does it happen when you turn the wheel a specific way, and not the other way?
It doesn't matter which way I turn it. You can hear something whining nearly all the time now.
LOL...
Originally Posted by jaylebo
Current
2008 M5 6 Spd
2000 Z3 2.8 5 Spd MSport
2012 X5 35d Sport
1995 540i 6 Spd
1992 535i 5 Spd
Former
1995 530iA
1986 635CSI 5 Spd
2011 X3 2.8 MSport
NiceOriginally Posted by jaylebo
I miss my e34
check your power steering fluid level. if it's low you need to add some. if the fluid looks foamy, drain it and refill it with the right type of fluid. i get a growling every 3-4 months or so and often find that my ps fluid is low or foamy. not sure how it gets so foamy.
Checked the fluid level - took almost a whole litre!!! Working perfect now. Feel like an idiot for not checking that first!!!
Thanks for the help guys.
