Originally Posted by
MarkD
Bret,
you can use the silver (grey) label EWS ECU in a non-EWS car but to do so, you need to remove the EPROM which has EWS functions in it (sw version 1 267 357 715) and replace it with a chip from a non-EWS car.
I make a chip to bypass the EWS in an EWS car, but it requires that all the EWS parts are still in the car. It would not work if you put the EWS ECU into a non-EWS car.
By the way, the EWS EPROM is not just the non-EWS code but with EWS added, it's got other features in it also such as more rev limiters (for each gear)
MarkD
