Results 1 to 8 of 8
Thread: Shifting in Auto/Sport mode
    Apr 2005
    Philadelphia
    Default Shifting in Auto/Sport mode
    Had a conversation with a friend of mine regarding manually shifting with a 95 530i auto transmission. Is this a problem? Should or shouldn't it be done?
    Aug 2005
    Toronto
    AFAIK, it's not good to do it too often, and you're kidding yourself if you think you're gaining any peformance, since the shift speeds are the same and you're just adding time to the shift by making the driver do it manually with a device that wasn't designed for quick changes.
    That goes, I think, for any auto tranny.
    Jay Lebo - Toronto, Canada
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    Sachs Suspension Kit
    E.A.T. Chip
    Apr 2005
    Philadelphia
    Quote Originally Posted by jaylebo
    So starting/leaving in sport 4 mode for instance, is same, if not better than shifting manually or leaving in D, for best performance.
    Jan 2005
    Melbourne Australia
    if you want a more agressive shift, i have seen a tranny chip with more agressive settings. havent tried it but worth a look.
    1994 540i Auto
    live fast; die sideways
    13.3 @ 104mph (not in the 540)
    15.4 @ 150 Kph in the 540 (24/9/07)
    Aug 2005
    Toronto
    Quote Originally Posted by stx133
    Yes, Dinan has one, I think.
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    E.A.T. Chip
    Apr 2005
    Philadelphia
    I have also heard of this chip. So in regards to not having a chip, shifting/ off the line speed will not be dramatically increased if using sport mode opposed to regular?
    Aug 2005
    Toronto
    Quote Originally Posted by saj3n
    I don't know if shifting manually will hurt your car, but someone else around here will know.
    I am CERTAIN that you're not gaining any performance by shifting yourself. In sport mode, the tranny shifts at redline as fast as it can. How can moving the stick yourself improve on that?
    Now, if you want to put the gear selector in, say, S2 for spirited driving through twisties, that's another thing. That's harmless and fun. But you leave the selector there. Don't move it through the gears. You're gaining nothing and you're using your transmission in a way for which it wasn't designed.
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    E.A.T. Chip
    Jan 2005
    Melbourne Australia
    The ONLY time manual shifting will help is on down change, when breaking into a corner. then you are still at the mercy of the computer. leave the shifter alone or get a manual. once you are in 'S' mode there is nothing you can do to get quicker acceleration.
    1994 540i Auto
  1. Automatic Steptronic Sport Mode
    By Dvious in forum 5 Series BMW
    Last Post: 04-17-2008, 12:32 PM
  2. Sport Mode !
    By Roderick in forum 5 Series BMW
    Last Post: 07-01-2007, 01:33 PM
  3. driving in sport mode?>
    By liquidtiger720 in forum 5 Series BMW
    Last Post: 05-27-2006, 10:36 PM
  4. Driving an Auto in Manual & Sport mode?
    By wareagle72 in forum 5 Series BMW
    Last Post: 03-17-2005, 12:05 PM
  5. Sport/Economy mode
    By SC David in forum 5 Series BMW
    Last Post: 04-17-2004, 03:47 PM
