Results 1 to 10 of 12
Thread: Air Compressor Harbor F, US Gen 60g $379
    Apr 2004
    Default Air Compressor Harbor F, US Gen 60g $379
    Air Compressor Harbor F US Gen 60g $379 with 12.85 cfm @ 90 psi is a lot of specs for the $. For light use, will the US Gen hold up or should I try to find a used 60 gal unit.
    How to tell if used unit is good?
    The 30/33 gal systems don't have power to run many air tools and sprayers. Biggest advantage of the 30 gal units seems to be 115v, portability, and the Sears package deal @ $329 of air tools with modest power but compatability with output of the 33 gal system.
    links? The pump is the important factor, tank size is not really relivant. My pump is about 13.5 at 90psi and the tank looks to be 30-35. I can run anything including sand blasting and painting.
    Boston & Attleboro MA
    I dont' think they have it online, but in the sears tool catalog they have a chart of what compressors can handle, there's a star system. The 30 gallon one mentioned, is like a 6 star, which means it can handle any tool. The only thing it cant do is multiple of certain tools at the same time. Having a 115/120v is better for home use unless your house can handle the 230v ones.
    Quote Originally Posted by Gene in NC
    Current
    2008 M5 6 Spd
    2000 Z3 2.8 5 Spd MSport
    2012 X5 35d Sport
    1995 540i 6 Spd
    1992 535i 5 Spd
    Former
    1995 530iA
    1986 635CSI 5 Spd
    2011 X3 2.8 MSport
    Gee... what exactly are you running? I can't imagine anything past a 30 gallon for home use. Only a shop would need something like 60 gallon... If your pump are not running for 50% of the time in use... 30 minutes on the hour... it is enough.
    Is this the one?
    Its listed at $499 here:
    http://www.harborfreight.com/cpi/cta...temnumber=3848
    Is it $379 in their latest sale?
    Sign up for their email sale list, because they send out 20% of one item coupons and 10% entire order ones quite often. They are valid on sale items...so that'd bring the price down to $303
    DanH
    1989 535iA 254k Miles
    1992 535iM 330k Miles
    the big tanks take forever to fill so to me id prefer a quick fill cause when I want my air I want it now! Mine eventually leaks back out after a few days through its regulator or something.
    Bethlehem, PA
    If you're looking for more than about 4-5 cfm @ 90psi you're essentially going to have to rule out 120VAC units. They will draw too much current for a typical 20A/12GA branch circuit.
    About large tanks: whether this works for you depends a lot on the on-off setpoints of the pressure switch. On HF's cheaper compressors, the unadjustable on-point is somewhere around 70 psi, so that if you have a large tank, it's going to spend a lot of time below 90 psi before the compressor restarts. It's possible they do this to make it easier to start the compressor without complex load-reduction mechanics. Whatever you buy, make SURE that you can set the low pressure limit switch to something higher than about 95psi.
    PA
    Our tank is i think 60 gallons, but the pump is able to do 120+ psi.
    Also, be sure to empty your tank frequently with the purge on the bottom and let the water out. **** will rust like whoa.
    Uh your suppose to drain the tank when its not in use
    Current
    2008 M5 6 Spd
    2012 X5 35d Sport
    1995 540i 6 Spd
    1992 535i 5 Spd
    Former
    1995 530iA
    1986 635CSI 5 Spd
    2011 X3 2.8 MSport
    Apr 2004
    DanH, yes pn is 3848. Must be on sale. No special indicatin except price tag, but theprice sure caught my eye.
  1. teh end tymes1!1!1 harbor freight cnc machines
    Last Post: 01-26-2009, 02:42 PM
  2. Replies: 5
    Last Post: 07-30-2007, 08:39 PM
  3. Harbor Freight 20% off coupon is back
    Last Post: 06-05-2006, 07:51 PM
  4. 20% off coupon at Harbor Freight. Can email
    Last Post: 03-14-2006, 10:34 PM
  5. Harbor Inside Track Member?
    By DaCan23 in forum 5 Series BMW
    Last Post: 01-27-2006, 04:34 PM
