did the ac ever work? have you had it charged or checked? if its not the evaporator leaking then you wouldnt need to touch it.
I've got some kind of heater core problem because my windshield is fogging up and I'm getting coolant odour in the cabin.
My A/C also doesn't work at all, though I have no idea why.
Is there any economy of scope by fixing these two items at the same time?
Not in the time I've known the car, no. Presumably, it did work at some time in the pastOriginally Posted by 632 Regal
No, not yet. I'm broke at the moment, but obviously I would want to rule out the easy fixes before I start looking at hard ones.Originally Posted by 632 Regal
Touch what, exactly? I really have NO idea why the A/C doesn't work. It just doesn't. The aux fan also does not work, which may or may not be related.Originally Posted by 632 Regal
I'm just wondering if I'm going to have easy access to any A/C components while I have the dash apart. If not, then then I'll save the A/C for another day. After a lottery win, perhaps.
Fans are activated by the AC and the thermo switch- my fan didn't work as the AC gas had dwindled away-or burned out somehow gradually. I just had it regassed and it now works fine on both speeds. No leaks!
I blamed the switch, the resistor, but it was actually that I was too lazy and cheap to regas it. The compressor can jam up due to non-use so you miight as well just get it done anyway. First step would be perhaps to check the switch's operation, then the resistor's connectivity (crumbs one has to pull apart the front of the car just to do that... ), checking it requires pulling brittle clips and connectors, why try fixing (f*#@ing) it when it ain't broke?
I'd be tempted to just regas without doing any of that as it could be fine, just not running due to the gas.
Just my 2c. Nick
I guess that seems like a reasonably place to start.Originally Posted by genphreak
My father bought the car from an independent European used car showroom, and the A/C was not working at that time. If it's just a matter of recharging the system, then I'm surprised the dealer didn't do that, as they could've asked more for the car if it'd had working A/C.
I think Bruno has the recharge equipment...
and once you have it fixed dont forget to run the a/c at least 10 15 minutes a month.......In the winter with the A/C on(and heat of course) It demists the whole car in seconds,even with a slight heater core leak!
Gone but not forgotten
if it was only recharging, the dealer would surely have done it!
Even the parts that were working when you bought it will likely be f*&ked if the ac has not been running for so long.
I spent a ton redoing my ac.
^°^ ><((({º>°°
I changed the evaporator in my W140 benz, about a 3 month job.
If you're having problems with both, i'd suggest changing everything while you're in there. I think it's always a whale of a job just to get to either and they're right close together.
Oh, I did repalce the drier as well- do they clog up? Maybe that was part of it...Originally Posted by jaylebo
