Hopefully it is not the heater core. Antifreeze smell maybe?
Good Luck.
There's a nusiance that I've been meaning to post, but...
The driver side windshield, and to a lesser degree, the side window... will fog. Here's the case:
Outside is colder... like -10c. Drive a bit, leave the vents open on climate sword and actual vents. Leave the car, come back, the driver's side is fogged.
Because I was there you say? I can have full passenger compliment and still only the driver side will fog.
When I wipe the condensation, it seems to have a slight oily feel to it.
If I manually close the blade (upper dash vents), then it's much better. There would only be a little bit, if any. Now I do hear the opening and closing whirrrrrr sounds when you turn on and off the car...
There seems to be a faint smell to it... like power steering fluid I surmise. I gather it must be coming from the dash vents because where there are partitions between the vents, the fog is thinner.
Good Luck.
sounds like a heater core... sweet smell of coolant.
^°^ ><((({º>°°
This is almost definitely the heater core, a seemingly common problem on E34's. My car has had the exact same symptoms for about a year except I occaisionally get a very strong sickly sweet smell that is definitely coolant. I have not had the time or money to fix it, so I just deal with it and top off the coolant every once in a while hoping the leak does not get worse, which it hasn't.
I never even thought it was coolant, lol. Yeah. I have a coolant leak, but it's not bad. I top off every now and thenOriginally Posted by Jimbo
Fromt he description its almost 100% surely your heater core. I went through the same several years ago.
That was the telltale sign that my heater core was leaking.Originally Posted by Qube
That's probably where your coolant is going. I bypassed my heater core, till I get it fixed (If ever). No more coolant loss.Originally Posted by Qube
If the heater core leak isn't very bad, just don't use the heater and watch the coolant level closely. If the coolant gets low and you overheat, it could worsen the heater core leak due to the added pressure.Originally Posted by Jimbo
Qube, I have the EXACT same problem:
http://www.bimmer.info/forum/showthread.php?t=17970
Although I'm nervous about it, a buddy and I have decided to tackle fixing it ourselves when the weather improves, using this guide:
http://www.homeofsbc.com/Fixes/Heater/heater.htm
Since we're both in Toronto, maybe we should get together and tackle the two cars as a three-man team, lending technical, moral and beer support?
