Results 1 to 10 of 11
Thread: WILL A 530i HEAD FIT ON A 535I???
    LONDON , UK
    Default WILL A 530i HEAD FIT ON A 535I???
    Hi, Does Anyone Know If The Head From A 1990 530i E34 Will Fit The Engine In My 1991 535i Sport? This Would Be Handy If Anyone Could Shed Any Light On The Situation As I Have A Clean 535 With A Niosy Camshaft And A Scabby Old 530 With A Sweet Head!! Cheers
    Elm Grove Farm, NC
    Might be helpful if you posted your location, or what market these cars were built for. In the USA, a 530i is a small V8, and there's no way a 530i head would fit a 535i.......
    Assuming the 530i is a version of the M30 6 cyl, I would be very surprised if that head did fit the 535i M30.....
    Bret.
    Boston & Attleboro MA
    This must be a euro question, because the states never got the 3.0L M30 in an E34.
    No it would not fit. While the valves are nearly identical, the bottom of the head would have to be widened to match the cylinder size. Have no clue if a mod like that is even possible.
    Quote Originally Posted by BEAGS
    Current
    2008 M5 6 Spd
    2000 Z3 2.8 5 Spd MSport
    2012 X5 35d Sport
    1995 540i 6 Spd
    1992 535i 5 Spd
    Former
    1995 530iA
    1986 635CSI 5 Spd
    2011 X3 2.8 MSport
    Hockinson, Washington
    You do know that the valves need adjusting from time to time?
    LONDON , UK
    Yeah ive had it looked at and its the camshaft for sure!
    LONDON , UK
    Quote Originally Posted by DaCan23
    Thanks for your help! Saves me breaking a good engine for no reason..
    LONDON , UK
    Quote Originally Posted by Rigmaster
    Bret.
    Cheers for the tips, yeah they did do a 530i with an M30 engine in england then they changed to the V8 in about 93ish...
    PA
    Guys, not true about the head being enlarged. M50 head fits on an M52.. and M50 on an S50 i believe.
    Boston, Ma
    The M52 just has a larger stroke, and a S50 barely has a larger bore so it wouldnt make that big of difference. All you need to do to make a M50 into a 2.8 is change the crank and rods, and if you put S50 crank in an M50 you get 2.9. Im sure the head would fit, but it wouldnt be as efficient, but maybe be more, because of increased CR with a smaller combustion chamber. Although a machine shope could take care of it for you if you got the head for a good deal.
    LONDON , UK
    Quote Originally Posted by bjl4776
    You seem to know ur business with the M52 and M50 and so on. what do you reckon about the M30 engines! Had much experience with them??
  1. 535i vs 530i transmissions
    By Jeff N. in forum 5 Series BMW
    Last Post: 05-23-2008, 10:49 AM
  2. 530i vs. 535i
    By Golgade in forum 5 Series BMW
    Last Post: 05-09-2008, 12:02 PM
  3. 1990 535i vs 1994 530i
    By chris_e34 in forum 5 Series BMW
    Last Post: 05-08-2006, 04:56 PM
  4. Replies: 8
    Last Post: 05-11-2004, 09:22 PM
  5. Replies: 14
    Last Post: 02-22-2004, 04:33 PM
