60 percent complete
| BMW Engines
Code | Engine | Years | Displacement | Power | Torque | Cam Config | Duration | Valves | Intake | Exhaust | Bore | Stroke | Compression | Fuel System |
| M30B28 | 2.8L I-6 | 1969-1981 | 2788cc | 192 bhp | 200 ft-lbs | SOHC | 260 Degrees | 12 | 46 mm | 36 mm | 86 mm | 80 mm | 9.00:1 | Dual Zenith D-draft Carbs |
| M30B30 | 3.0L I-6 | 1973-1978 | 2985cc | 176 bhp | 185 ft-lbs | SOHC | 260 Degrees | 12 | 46 mm | 36 mm | 89 mm | 80 mm | 8.10:1 | Bosch L-Jetronic |
M30B32 | 3.2L I-6 | 1977-1984 | 3210cc | 181 bhp | 195 ft-lbs | SOHC | 272 Degrees | 12 | 46 mm | 36 mm | 89 mm | 86 mm | 8.40:1 / 8.80:1 | Bosch Motronic |
| M30B34 | 3.4L I-6 | 1984-1987 | 3430cc | 208 bhp | 225 ft-lbs | SOHC | 264 Degrees | 12 | 47 mm | 36 mm | 92 mm | 86 mm | 9.00:1 | Bosch Digital Motronic 1.1 |
| M30B35 | 3.4L I-6 | 1988-1993 | 3430cc | 208 bhp | 225 ft-lbs | SOHC | 264 Degrees | 12 | 47 mm | 36 mm | 92 mm | 86 mm | 9.00:1 | Bosch Digital Motronic 1.1 |
M102B32 | 3.2L I-6 Turbo | 1979-1983 | 3210cc | 252 bhp | 225 ft-lbs | SOHC | 260 Degrees | 12 | ??? | ??? | ??? | ??? | ??? | Bosch L-Jetronic |
M106B35 | 3.2L I-6 Turbo | 1983-1986 | 3453cc | 252 bhp | 227 ft-lbs | SOHC | 264 Degrees | 12 | ??? | ??? | ??? | ??? | ??? | Bosch Motronic |
| BMW Engines
M50B25 | 2.5L I-6 | 1990-1995 | 2494cc | 189 bhp | 181 ft-lbs | DOHC/VANOS | 228 | 24 | 33 mm | 30.5 mm | 84 mm | 75 mm | 10.5:1 | Bosch Motronic DME 3.3.1 |
| M52B25 | 2.5L I-6 | 1996-1999 | 2494cc | 170 bhp | 181 ft-lbs | DOHC/VANOS | 228 | 24 | 33 mm | 30.5 mm | 84 mm | 75 mm | 10.5:1 | DME MS 42.0 SIEMENS |
| M52B28 | 2.8L I-6 | 1994-1999 | 2793cc | 190 bhp | 207 ft-lbs | DOHC/VANOS | 228 | 24 | 33 mm | 30.5 mm | 84 mm | 84 mm | 10.2:1 | DME MS 41.1 SIEMENS |
| M52B28 TU | 2.8L I-6 | 1997-2000 | 2793cc | 193 bhp | 207 ft-lbs | DOHC/DUAL VANOS | 228 | 24 | 33 mm | 30.5 mm | 84 mm | 84 mm | 10.2:1 | DME MS 42.0 SIEMENS |
| M54B25 | 2.5L I-6 | 1999- | 2494cc | 184 bhp | 175 ft-lbs | DOHC/DUAL VANOS | 240 | 24 | 33 mm | 30.5 mm | 84 mm | 75 mm | 10.5:1 | DME MS 43.0 SIEMENS |
| M54B30 | 3.0L I-6 | 1999- | 2979cc | 225 bhp | 214 ft-lbs | DOHC/DUAL VANOS | 240 | 24 | 33 mm | 30.5 mm | 84 mm | 89.6 mm | 10.2:1 | DME MS 43.0 SIEMENS |
| M56B25 | 2.5L I-6 | 2002- | 2494cc | 184 bhp | 175 ft-lbs | DOHC/DUAL VANOS | ??? | 24 | ??? mm | ??? mm | 84 mm | 75 mm | 10.5:1 | ??? |
| BMW Engines
| M20B25 | 2.5L I-6 | 1986-1991 | 2492cc | 168 bhp | 164 ft-lbs | SOHC | 260 | 12 | 42 mm | 36 mm | 84 mm | 75 mm | 8.80:1 | Bosch Motronic |
| M20B27 | 2.7L I-6 | 1983-1988 | 2693cc | 121 bhp | 170 ft-lbs | SOHC | 236 | 12 | 40 mm | 34 mm | 84 mm | 81 mm | 9.00:1 | Bosch Motronic |
| M60B30 | 3.0L V-8 | 1992-1996 | 2997cc | 215 bhp | 214 ft-lbs | DOHC | 246/242 | 32 | 35 mm | 30.5 mm | 84 mm | 68 mm | 10.5:1 | Bosch Motronic DME 3.3.1 |
| M60B40 | 4.0L V-8 | 1992-1996 | 3982cc | 282 bhp | 296 ft-lbs | DOHC | 246/242 | 32 | 35 mm | 30.5 mm | 89 mm | 80 mm | 10.0:1 | Bosch Motronic DME 3.3.1 |
| M62B35 | 3.5L V-8 | 1996-2004 | 3498cc | 235 bhp | 320 ft-lbs | DOHC/VANOS | ??? | 32 | 35 mm | 30.5 mm | 84 mm | 78.9 mm | 10.0:1 | Bosch Motronic DME 5.2 |
| M62B44 | 4.4L V-8 | 1996-2004 | 34398cc | 286 bhp | 420 ft-lbs | DOHC/VANOS | ??? | 32 | 35 mm | 30.5 mm | 92 mm | 82.7 mm | 10.0:1 | Bosch Motronic DME 5.2 |
| M62B46 | 4.6L V-8 | 1996-2004 | 4619cc | 347 bhp | 480 ft-lbs | DOHC/VANOS | ??? | 32 | 35 mm | 30.5 mm | 82.7 mm | 89 mm | 10.0:1 | Bosch Motronic DME 7.2 |
Current
2008 M5 6 Spd
2000 Z3 2.8 5 Spd MSport
2012 X5 35d Sport
1995 540i 6 Spd
1992 535i 5 Spd
Former
1995 530iA
1986 635CSI 5 Spd
2011 X3 2.8 MSport
