+ Reply to Thread
Results 1 to 4 of 4
Thread: 60 percent complete
    Boston & Attleboro MA
    Default 60 percent complete
    BMW Engines
    Code
    Engine
    Years
    Displacement
    Power
    Torque
    Cam Config
    Duration
    Valves
    Intake
    Exhaust
    Bore
    Stroke
    Compression
    Fuel System
    M30B28
    2.8L I-6
    1969-1981
    2788cc
    192 bhp
    200 ft-lbs
    SOHC
    260 Degrees
    12
    46 mm
    36 mm
    86 mm
    80 mm
    9.00:1
    Dual Zenith D-draft Carbs
    M30B30
    3.0L I-6
    1973-1978
    2985cc
    176 bhp
    185 ft-lbs
    SOHC
    260 Degrees
    12
    46 mm
    36 mm
    89 mm
    80 mm
    8.10:1
    Bosch L-Jetronic
    M30B32
    3.2L I-6
    1977-1984
    3210cc
    181 bhp
    195 ft-lbs
    SOHC
    272 Degrees
    12
    46 mm
    36 mm
    89 mm
    86 mm
    8.40:1 / 8.80:1
    Bosch Motronic
    M30B34
    3.4L I-6
    1984-1987
    3430cc
    208 bhp
    225 ft-lbs
    SOHC
    264 Degrees
    12
    47 mm
    36 mm
    92 mm
    86 mm
    9.00:1
    Bosch Digital Motronic 1.1
    M30B35
    3.4L I-6
    1988-1993
    3430cc
    208 bhp
    225 ft-lbs
    SOHC
    264 Degrees
    12
    47 mm
    36 mm
    92 mm
    86 mm
    9.00:1
    M102B32
    3.2L I-6 Turbo
    1979-1983
    3210cc
    252 bhp
    225 ft-lbs
    SOHC
    260 Degrees
    12
    Bosch L-Jetronic
    M106B35
    3.2L I-6 Turbo
    1983-1986
    3453cc
    252 bhp
    227 ft-lbs
    SOHC
    264 Degrees
    12
    Bosch Motronic
    BMW Engines
    Code
    Engine
    Years
    Displacement
    Power
    Torque
    Cam Config
    Duration
    Valves
    Intake
    Exhaust
    Bore
    Stroke
    Compression
    Fuel System
    M50B25
    2.5L I-6
    1990-1995
    2494cc
    189 bhp
    181 ft-lbs
    DOHC/VANOS
    228
    24
    33 mm
    30.5 mm
    84 mm
    75 mm
    10.5:1
    Bosch Motronic DME 3.3.1
    M52B25
    2.5L I-6
    1996-1999
    2494cc
    170 bhp
    181 ft-lbs
    DOHC/VANOS
    228
    24
    33 mm
    30.5 mm
    84 mm
    75 mm
    10.5:1
    DME MS 42.0 SIEMENS
    M52B28
    2.8L I-6
    1994-1999
    2793cc
    190 bhp
    207 ft-lbs
    DOHC/VANOS
    228
    24
    33 mm
    30.5 mm
    84 mm
    84 mm
    10.2:1
    DME MS 41.1 SIEMENS
    M52B28 TU
    2.8L I-6
    1997-2000
    2793cc
    193 bhp
    207 ft-lbs
    DOHC/DUAL VANOS
    228
    24
    33 mm
    30.5 mm
    84 mm
    84 mm
    10.2:1
    DME MS 42.0 SIEMENS
    M54B25
    2.5L I-6
    1999-
    2494cc
    184 bhp
    175 ft-lbs
    DOHC/DUAL VANOS
    240
    24
    33 mm
    30.5 mm
    84 mm
    75 mm
    10.5:1
    DME MS 43.0 SIEMENS
    M54B30
    3.0L I-6
    1999-
    2979cc
    225 bhp
    214 ft-lbs
    DOHC/DUAL VANOS
    240
    24
    33 mm
    30.5 mm
    84 mm
    89.6 mm
    10.2:1
    DME MS 43.0 SIEMENS
    M56B25
    2.5L I-6
    2002-
    2494cc
    184 bhp
    175 ft-lbs
    DOHC/DUAL VANOS
    24
    ??? mm
    ??? mm
    84 mm
    75 mm
    10.5:1
    BMW Engines
    Code
    Engine
    Years
    Displacement
    Power
    Torque
    Cam Config
    Duration
    Valves
    Intake
    Exhaust
    Bore
    Stroke
    Compression
    Fuel System
    M20B25
    2.5L I-6
    1986-1991
    2492cc
    168 bhp
    164 ft-lbs
    SOHC
    260
    12
    42 mm
    36 mm
    84 mm
    75 mm
    8.80:1
    Bosch Motronic
    M20B27
    2.7L I-6
    1983-1988
    2693cc
    121 bhp
    170 ft-lbs
    SOHC
    236
    12
    40 mm
    34 mm
    84 mm
    81 mm
    9.00:1
    Bosch Motronic
    M60B30
    3.0L V-8
    1992-1996
    2997cc
    215 bhp
    214 ft-lbs
    DOHC
    246/242
    32
    35 mm
    30.5 mm
    84 mm
    68 mm
    10.5:1
    M60B40
    4.0L V-8
    1992-1996
    3982cc
    282 bhp
    296 ft-lbs
    DOHC
    246/242
    32
    35 mm
    30.5 mm
    89 mm
    80 mm
    10.0:1
    M62B35
    3.5L V-8
    1996-2004
    3498cc
    235 bhp
    320 ft-lbs
    DOHC/VANOS
    32
    35 mm
    30.5 mm
    84 mm
    78.9 mm
    10.0:1
    Bosch Motronic DME 5.2
    M62B44
    4.4L V-8
    1996-2004
    34398cc
    286 bhp
    420 ft-lbs
    DOHC/VANOS
    32
    35 mm
    30.5 mm
    92 mm
    82.7 mm
    10.0:1
    M62B46
    4.6L V-8
    1996-2004
    4619cc
    347 bhp
    480 ft-lbs
    DOHC/VANOS
    32
    35 mm
    30.5 mm
    82.7 mm
    89 mm
    10.0:1
    Bosch Motronic DME 7.2
    Current
    2008 M5 6 Spd
    2000 Z3 2.8 5 Spd MSport
    2012 X5 35d Sport
    1995 540i 6 Spd
    1992 535i 5 Spd
    Former
    1995 530iA
    1986 635CSI 5 Spd
    2011 X3 2.8 MSport
    Bethlehem, PA
    The torque figures for M20B27 and M62B35/44/46 look way too high.
    Kentucky
    Quote Originally Posted by SRR2
    maybe for the m62b35, but for m20b27? 170lb.ft? It has .2 liters on the m20b25, which I know for a fact is correct at 164lb.ft.
    Bethlehem, PA
    121hp and 170 lb-ft don't seem to go together unless it's a diesel or the top engine speed (where peak power is developed I mean) was artificially limited. I don't have any definitive data on it, though. Just that the relationship looks too far off for a normal modern gasoline engine. Definitely the torques given for the M62s are wrong. I have the M62TU. Torque is specified at 324 lb-ft. The displacement of the M62B44 is wrong too, should be 4398. The M62B46 is dual Vanos. There are two major versions of the 4.4L M62. The M62 non-TU delivers 310lb-ft of torque, the M62TU 324 lb-ft. The non-TU uses Bosch Motronic 5.2.1, the TU version uses ME7.2 (which feature throttle-by-wire, which earlier versions do not). The TU version, however is not the M62B46 which appears to be the version in the E60. So, it looks like you're missing an entire entry for the E39 vintage M62TU. If you want to go really , you might want to distinguish between the m/y 1997 and 1998 4.4L motors. The former uses Motronic 5.2 (no Vanos), the latter 5.2.1 (Vanos).
    By the way, the unit for torque is "lb-ft", not "ft-lb". The latter is a unit of work. Don't blame me, I don't make the rules. Like it or not, lb-ft is torque, ft-lb isn't, and they're not interchangeable.
+ Reply to Thread
  1. FS: complete mint blk int for E34
    By Lee in Ottawa in forum 5 Series BMW
    Last Post: 05-25-2006, 02:34 PM
  2. ::.. Transformation... almost complete...
    By Qube in forum 5 Series BMW
    Last Post: 04-19-2006, 08:54 AM
  3. OT a game I cant complete
    Last Post: 01-11-2006, 11:46 AM
Tags for this Thread
  • You may post replies
