It is likley the AFM air vane (flap) is jamming inside the aluminum AFM housing.Originally Posted by t_marat
If you undo the large hose clamp and pull the intake boot (air filter side) use a good torch to inspect the edges around the flap for scratches. It might just be the cold shrinking the AFM housing (I had one in Australia that was warped due to the 40+ heat once). Easy to fix, repalce the AFM or take it off and file the edges of the flap so it moves freely again. Could be fuel too, but most likely the cold is getting to the aged intake components...
