Um, I don't know anything about the self leveling, but how beefy are the guns? I'd consider driving it without PS, at least for awhile until I found a new car I liked.
I think it is time to retire my baby
Some of you may be aware of a little problem I had with power steering fluid leaking out. Well I finally took it to a garage who has told me all the self levelling pipes under the rear of the car have corroded, and that is where the fluid has been leaking from.
They recon I am looking at about 10hrs labour, plus parts...
I didn't pay a lot for the car, and I don't see the point in paying more to fix it, so I think it is time to downgrade...
Since the old girl aint gonna be worth much, I thought it best to part her out... What do you guys recon? Should I fix and keep her, or chop her up??(I quite fancy an e30 325i)...
And yes, I do need parts, lots of them. If you decide to part it out, I'll email you the list.
Why not just get the kit to eliminate the LAD, think it was around $250?
1988 M3 - Track rat
1989 325iC
1995 530iM
2000 323iT - UUC BBK, PSS9 Coilovers
2005 GMC HD Crew
Or even just pick up a pair of used rear shock/spring assemblies from a boneyard.Originally Posted by brodee
Loop back the SLS feed/return pipes in the engine bay using a length of brake flex hose at joint 7 in link below (should be typical for your car). Don't block the pump output though, you'll kill it fast.
http://www.realoem.com/bmw/showparts...26&hg=33&fg=50
Anthony
03/64 production
Originally Posted by Anthony (M5 in Calgary)
I have an entire set of coil springs and used struts...
Does the engine run? Yes? Don't give up just yet! I'm sure we'll help you out. Source around for enthusiasts in your area as well.
That car only has 1/2 the miles on it required to retire
1993 525iA M50TU
Black on Black...need pics
208,888 miles
I busted my sweetheart (1994 530i) right front fender and turn signal. Can I ask for a transplant from your car?
Please let me know if you decide to donate her parts.
Arul
