Results 1 to 5 of 5
Thread: 6 weeks still no heat
    Columbus, Ohio
    Default 6 weeks still no heat
    I need some help. My alternator went out on my 91 525i. In the process of replacing the alternator I had to remove the top radiator hose and drain some coolant. Since then I have had no heat. Replaced thermostat, thermo housing, water pump has metal impeller, replaced heater valve, auxiliary heater motor works well, gone through 2 gallons of cool blue in bleeding, no leaks in coolant system, still no heat. Any suggestions?
    Calgary AB Canada
    [QUOTE=Steve Nmaeth]I need some help. My alternator went out on my 91 525i. In the process of replacing the alternator I had to remove the top radiator hose and drain some coolant. Since then I have had no heat. Replaced thermostat, thermo housing, water pump has metal impeller, replaced heater valve, auxiliary heater motor works well, gone through 2 gallons of cool blue in bleeding, no leaks in coolant system, still no heat. Any suggestions?[/QUOTE
    On my M20 powered 325is it took a good rev to purge the air despite all other attempts. Have you been driving the car much? Any other symptoms? Overheat?
    Anthony
    03/64 production
    PA
    wow i thought you meant your house. our second floor heater unit failed about a month ago and was off for over 2 weeks, the upstairs was FREEZING. I had 6 blankets at night.
    Did you turn the cabin heat controls to full heat position, run the engine, and bleed the air from the system via the bleed screw?
    Columbus, Ohio
    Yes,
    I have done all of that. I have a minor leak in the expansion tank which all of last winter. Would that be enough to screw things up?
  1. OT: I'm going to be working in San Jose, CA for 4 weeks
    By DanDombrowski in forum 5 Series BMW
    Last Post: 06-08-2007, 03:59 PM
  2. Heat All The Time=Heat Valves?
    By slupregime in forum 5 Series BMW
    Last Post: 07-29-2006, 02:34 PM
  3. Had 97 540i for 3 weeks now
    By DukeNeverwinter in forum 5 Series BMW
    Last Post: 11-02-2005, 05:37 PM
  4. So the car's had a rough few weeks.
    By Sean H in forum 5 Series BMW
    Last Post: 01-31-2005, 11:30 PM
  5. My first two weeks of E34 535i ownership.
    By pundit in forum 5 Series BMW
    Last Post: 01-19-2005, 11:54 PM
