Results 1 to 10 of 18
Thread: control arms nauseum
    Default control arms nauseum
    I know the know hows to remove the ball joints, but how to put them back on without the new ball joint spinning trying to tighten it? Seems a lot of downforce is needed to fully meet the torque settings required. help
    one of the reasons I'm broke...
    Quote Originally Posted by romeox929
    BigKriss and I just jack up the steering arm so it gradually pressures the joint with the weight of the car (just enough). Worked fine. Be careful not to lift the car off the jack stands and/or otherwise make it fall on you, a phat e34 and phlatter driver makes for a definate no-show on race day mate... Nick
    ps- oh and be creful with your dust boots, sometimes they don't spin on the joint (I oiled mine with 2 drops of sewing machine oil and made sure they did- one of our arms wanted to rip the boot apart when the ball-joint's was twisted within the arm (as it does in operation), a contaminated joint would only have lasted lasted a 6 months on the car.. wrecking- so a boot means you will be doing it again be4 very long. Nick
    Quote Originally Posted by genphreak
    BigKriss and I just jack up the steering arm so it gradually pressures the joint with the weight of the car (just enough). Worked fine. Be careful not to lift the car off the jack stands adn/or otherwise make it fall on you, phat e34 and phlatter driver makes for a definate no-show on race day mate... Nick
    which point on the car did you guys meet the steering arm to? TIA!
    Strut
    V
    Thrust Arm
    V
    Steering Arm
    V
    Lower Control Arm
    V
    Jack
    First nut to torque up was the LCA- that one is impossible to get to when you have the steering arm mounted up to the strut (the LCA thread is obscured by the strut as it sticks up through it). The three (3) mounting nuts torque to 83Nm (& be sure to use Nyloc on all the steering arm nuts, CA nuts inc.)). The CA nuts themselves are 83 or 110Nm, I can't remember sorry and should be self locking Nyloc-types also.
    Strut
    V
    Thrust Arm
    V
    Steering Arm
    V
    Lower Control Arm
    V
    Jack
    not exactly the info I was looking for because I have the bentley manual. So how do you torque the LCA if it's impossible? thrust arm? sorry if I'm being difficult, but I can't justify going to the mechanic to pay him something I can do for free. again, thanks
    woops, I didn't make this clear- do not mount the steering arm plate to the strut before torquing the LCA nut- thus *not* obscuring the nut
    so, which part of the car did you put the weight on the steering arm to torque the LCA/UCA?
    When everything was bolted up we put the car onto some ramps (enabling us to get to the control arm bolts) getting a final torque.
    dude! use a nut without the self locking part on it and snug things together then use the self locking nut.
    Quote Originally Posted by BigKriss
    oh, I'm not talking about the bolts attached to the chassis, but the ones on the steering arm.
  1. e34 Control Arms ('90 535)
    By bimmerred535i in forum 5 Series BMW
    Last Post: 04-06-2009, 06:02 PM
  2. About to do thrust arms, control arms, and shocks
    By 530iBall in forum 5 Series BMW
    Last Post: 09-24-2007, 12:20 AM
  3. thrust arms or upper control arms
    By gsxr9 in forum 5 Series BMW
    Last Post: 01-25-2007, 11:02 PM
  4. Replies: 2
    Last Post: 10-29-2004, 09:16 PM
