front brakes are a direct swap and a nice improvment, the rears are the same size but a slightly different offset so they don't work. sway bars may or may not be bigger on the 735, i had a front bar from a 740 on my 535 that was a couple mm bigger. the push button hvac system is way different but if you wanted to totally gut the interior from the seats forward and swap everything you may be able to get it to work, but personally i like the cable control vents better so i can decide where the air goes, automatic climate control systems usually piss me off
