Results 1 to 9 of 9
Thread: Alternators
    Barrie Ontario, Canada
    Default Alternators
    I need a new alternator as far as i know, Everytime i leave a light on or car door open the battery just drains like a mother ****a. any ideas? is it just the battery or is the alternator a problem as well??
    J.McWatters
    Roswell New Mexico
    i know that my car uses a battery ever two years.
    Maybe you should take it to autozone and have them test it????
    hmm good idea.
    J.McWatters
    Jun 2005
    Cleveland, OH
    FWIW... autozone isn't the end all of battery testing....
    I have had batteries that tested good at autozone... that wheren't worth the metal in them....
    I miss my e34
    Default Unlock your OBC and test voltage at ...
    different situations (Shogun has written extensively about the matter).
    If voltage test OK, guess you problem is the battery, as it is not holding/receiving charge. If voltages are low, then it is possible you have a weak regulator in the alternator.
    Javier
    exactly, i guess worn out battery if the lights are bright when the car is running.
    95 E34 530I V2.34
    well yea we charged it. then drove it then when i turned it off it wouldnt start again. so had to boost it. lights are all fine as usual. it just dies immediately
    J.McWatters
    Mar 2004
    Brisbane, Australia
    get a voltmeter and check the voltage at the battery when the car is running and also at the alternator. put on your lights and wipers etc and see how much the voltage drops, if any. if it stays consistent then your alternator is fine. should be around 13.8 volts
    Default The OBC is a handy voltmeter if you unlock ...
    Hidden Functions. Test 9 is a voltage reading at + post in engine compartment.
    Javier
  1. FS:Hella voltage regulator for Bosch alternators-new
    By shogun in forum Swap Meet - Classified Ads
    Last Post: 03-03-2020, 09:43 AM
  2. M60s and alternators
    Last Post: 12-28-2009, 02:03 AM
  3. alternators and starters direct
    Last Post: 08-22-2009, 08:18 PM
  4. A question about alternators
    By genphreak in forum 5 Series BMW
    Last Post: 03-04-2007, 04:05 AM
  5. Bosch vs Valeo alternators
    By Wyn in forum 5 Series BMW
    Last Post: 02-07-2006, 11:37 PM
