the windows/sun roof is the "comfort relay" it's in a small box under the dash by the column, i can't remember the exact position out of 4 or 5 spots in the box it's a tall relay and the problem is a bad solder joint on the board inside
the faint turn signal is a bad ground somewhere on the car (bad ground can back track a circuit to stuff you wouldn't beleave), hard to say where just start checking plugs and bulb sockets on the effected areas if that comes up dry look at the harness for brown wires grounding to the body and check that connection
