Results 1 to 8 of 8
Thread: how can make sure tranny is 4hp22 (replaced by junk yard dealer)?
    Jul 2004
    Default how can make sure tranny is 4hp22 (replaced by junk yard dealer)?
    Without taking the tranny out, can I tell by the way the sump pan looks or something like that, if it was replaced with a 4hp22?
    The reason I ask is it feels like it has 5 gears, which according to Bentley's manual, the 4hp22 has four gears. And it has a dipstick which the manual doesn't mention this model has.
    I can take a picture of the sump pan if that would help.
    Also, the manual mentions a ATF filler pipe. I assume that's how you add fluid - where is that?
    Here's an article that shows a tranny service on a 4hp22. Hopefully you can identify it.
    http://www.pelicanparts.com/BMW/tech...Fluid_Auto.htm
    That fact that you have a fill tube makes me almost sure it is a 4hp22. There is a metal tag on the driver side, near the pressure taps, but I'm sure you checked that. You can use the tube for the dipstick to add a little. Otherwise the drain/fill plugs on the sump.
    Default I do have a ZF 4hp22 and It does not have the extra ...
    pan shown on figure 4 of the link, nor my pan is that shape. It does have a dip stick in the filling tube (Just as an old Chevrolet).
    Javier
    Default The transmissioin in that article is not the zf4hp22eh its a
    gm strassbourg used on the 525's, the 4hp22eh was used on 535s
    Quote Originally Posted by tim
    Default You don't state what year and model your car is?
    The 4hp22 eh came with a dipstick and the lock up converter makes it feel
    almost like a 5th gear. The pan is shaped like this
    Quote Originally Posted by notesguy
    Default Yes it does, but I have never feel the sense of a 5th? ...
    Actualy, if I run SD or E3, I can feel it holding 3rd (as it does), without much need of going in 4th.
    Think I need to drive a little faster to feel it!!!
    Javier
    Oops, sorry about the link.
    Kentucky
    right on. if you are accelerating slowly, you can definitely feel/hear it go into lockup mode which feels like 5th.
    I don't think any other e34 tranny can be fitted instead of the 4hp22. The later m50 gm trannies, along with all the ones from 530s and 540s have different bell housings, shape, length etc ...
  1. 4HP22/EH tranny question
    Last Post: 09-22-2009, 07:46 PM
  2. Look at what I got fron the junk yard
    Last Post: 02-04-2009, 07:55 PM
  3. DIY repair ZF tranny 4HP22/24
    Last Post: 10-07-2007, 08:57 PM
  4. Replies: 25
    Last Post: 03-18-2007, 09:58 PM
  5. 4HP22 Tranny problem...you out there Kurt???
    By Robert K in forum 5 Series BMW
    Last Post: 06-12-2004, 10:45 AM
