I think there are two options available today...
...and I'm not sure what the market would be for a third. Bruno tried to market one of the current options and I think I have the only copy he sold.
Whit's right - you can replace the AFM with the Split Second PSC-somethingorother unit. This unit can either format a MAF signal to the ECU or - as Martin is doing - replace the air flow sensor altogether with a MAP sensor. He's got a fuel table that little pretty darn close for as a starting point however he has done enough mods that you'd need to tweek it to get it totally right. His major mod that would effect his table is his swapout of the stock 19lb injectors for 21lb injectors. He also has a 284 reground cam and headers similar to yours. I would suspect the cam in particular might effect the manifold pressure characteristics such that the map would be off vs. a stock cam.
Or - you can run what I have. Available from the rebranded Pro Flow systems (Martin has their new link somewhere), it's a ford mass air flow meter with a black box that allows you to condition the voltage signal to the ECU. Basically a translation unit that takes voltage in from the MAF and allows you to map it to a voltage out for the ECU.
The splitsecond will do what mine will OR run as a MAP unit. And it's cheaper. So, I think that's the direction you want to go if you do jump in.
To correctly setup either unit, you need to have a wideband O2 sensor. Both Martin and I are running the Innovate LC-1 unit. Tuning without this tool was a fools effort - there is just no way you can get the mixture correct without without it. Oh, you can get the car to run and it may even run OK, but without the wideband that's all you ever get. Both of our cars are running *much* better now that we've got the mixtures close via the wideband.
Chip wise, we're both running the conforti chip. No reason other than we had both purchased this chip before Mark had his out. I'd recommend his if you have a choice.
It's been fun to learn how to setup these systems. I've learned a lot along the way and I think the car is better for it. However, you should be prepped to get the right tools and be willing to invest some time.
I think you should go for it...we'll help you out whichever way you go. We've been the board pioneer's here - it's time for some others to jump on in...
Bellevue WA
86 Porsche 951 - Track Toy
