Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Valve Cover Paint
    Hockinson, Washington
    Default Valve Cover Paint
    I had decided to Paint my valve cover to make it look like 535ise's valve cover while i had it off to adjust my valves.
    Prep: I got the paint on the 20th and prepped it that day and the next. I first used soap and water to get much of the looser grime off. I then took it outside (so the fumes didnt suffocate me) and used paper towels, q-tips and paint thinner for about an hour try to get it clean enough so that when swabbed with a paint thinner soaked q-tip it would come back clean. I got it nearly perfect and the switched to brake cleaner (nasty stuff) which proved to be better for removing baked on grime deposits than the paint thinner. I then put it in the sink and used an "aluminum-ware scouring brush" (i have no idea why it was even here) to ! remove the last two remmnants of cosmoline from the aluminum. I then did one final wipe-down with the brake cleaner and pronouced the surface prepped. I then masked the oil-filler tube and the threaded studs.
    Painting: My older brother, having much more experience with spray paint than me, offered to spray the valve cover; so took him up on the offer and soon it was drying in the required 70 degree heat in the shop above the lower garage (where i park). The directions on the can recommened using a hair dryer or oven shortly after applying to "tighten the wrinkles and accelerate the drying process", so i used a hair dryer on it for about 10 minutes while wearing a chemical respirator.
    Sanding: After the requisite five days of drying time had elapsed, i set out to sand the raised areas down to metal and create a polished surface. I started with 60 grit paper (probably a bit too high) and removed most of the paint. Then i switched to 100 grit paper and removed the last of the paint and began the polishing procedure. At this point it had a kind of brushed metal appearance. I used 220 and finally 400 grit paper to create a polished surface on the raised areas.
    The finished product actually looks a lot better in real life than it does in a photograph (as do most things i take pictures of) but these should give you a general idea of what it looks like.
    Blurry
    Bad angle, decent quality
    Blurry
    Melbourne, Australia
    Looks very nice!
    What paint was used?
    I used VHT high temperature "wrinkle plus."
    Alex, that's an incredible job! Sounds like a big return on a cost effective cosmetic upgrade.
    best, whit
    Nice job.
    Awesome job! I love the way it turned out.
    Jun 2005
    Cleveland, OH
    Looks great....
    I miss my e34
    Central NJ - USA
    so u didn't put a clear on the raised parts?
    I thought about using a clearcoat, but i didnt have any and i decided to take the chance on whatever corrosion or whatever that might occur. I dont think polished aluminum is very reactive, so i shouldnt have any problems, especially since it wont be directly exposed to the weather.
    Default Looks great!
    I sent mine in for a crinkle powder coat leaving the raised stuff clear as well. I think you will be fine without a clearcoat. Just keep it as clean as possible
  1. Replies: 2
    Last Post: 03-25-2009, 07:47 PM
  2. valve cover paint
    Last Post: 05-09-2007, 03:51 PM
  3. m60 valve cover paint??
    By PhilipJCaputo in forum 5 Series BMW
    Last Post: 04-21-2005, 10:52 AM
  4. Engine cover re-paint
    By andyman32 in forum 5 Series BMW
    Last Post: 10-15-2004, 08:05 PM
  5. Valve Cover Paint
    By hinchcliffe in forum 5 Series BMW
    Last Post: 05-10-2004, 07:41 AM
