Results 1 to 2 of 2
Thread: sot: how can i read codes on my 87 325e?
    SCHUYLKILL COUNTY, PA.
    Default sot: how can i read codes on my 87 325e?
    the only warning is the check engine light.
    thanks
    tim s.
    Jun 2005
    Cleveland, OH
    Quote Originally Posted by tim s
    thanks
    tim s.
    I am 95% sure that the stomp test will work....
    I miss my e34
  1. ABS blinking codes, how do you read them
    Last Post: 10-22-2010, 07:36 PM
  2. Has anyone read fault codes with Carsoft
    By bmw540 in forum 5 Series BMW
    Last Post: 12-13-2006, 08:53 AM
  3. Can OBD2 code reader read E34 codes thru DL connector?....
    By Bellicose Right Winger in forum 5 Series BMW
    Last Post: 09-27-2006, 07:35 AM
  4. Can you read check engine codes through OBC?
    By Strap in forum 5 Series BMW
    Last Post: 10-18-2005, 06:58 PM
  5. Need to read codes on OBDII '97 Z3 2.8 Best way?
    By Warren N.CA in forum 5 Series BMW
    Last Post: 08-21-2004, 04:28 PM
