I wouldn't. Do a search.
please let me know i bought the e34 used when it has 100k miles now it has 200k miles.....i know for a fact w/in the last 100k miles the automatic tranny oil/filter has never been changed......
I would change the filter and only the fluid that comes out with the filter change only. Change the filter every 30k after the same routine.
If tranny is acting funky, you gotta change the fluid and filter.
632 regal,
i am going to change the tranny filter and fluid that i drain. now should i repeat this procedure every 30k from now on (filter and drained fluid)??
exactly. if you flush it the chances of the trans failing is a lot higher then never changing it, if you only change out the 3 or so qts its not so dramatic plus your trans will like the more easy flow through the new filter instead of having to suck it through a bunch of mud. Make sure to get quality parts, some cheaper aftermarkets can leak around the fluid pickup.
Originally Posted by Young Pete
In my humble opinion, a change MAY do you no harm. A flush is a no-no. Even so, you may want to spread this over several cycles and change a few quarts at a time.
I think we are speaking the same language here...lol just different words.
Originally Posted by Qube
Mechanics I know suggest if it hasn't been changed, leave it alone until it fails. Even a drain and refill may end up dislodging some gunk that will plug a passage. Save your money now for the rebuild later, its' coming.
If you do change it consider using an additive such as Wynn's. The trans shop that just rebuilt my trans uses it on all cars they service.
never EVER use any additives! The only thing recommended is injector cleaners.
