Originally Posted by
lowell
Well, I know I've talked about this a ton of times (do a search!?!), but what the...
The problem can be caused by an electrical or mechanical malfunction, and it still hasn't been identified as either. Can the lock be MANUALLY manipulated from inside the car? If it can, then the more critical parts of the linkage are operational. If it CAN'T (and this probably won't be the case, because the rest of the car would immediately unlock when it realized that the pass front door won't lock), there's a physical problem with the linkage or, more likely, the actuator has fused up.
If the lock can be manually set, the actuator is either faulty or it has "walked" over time. The actuator is mounted with two screws in oblong holes. It has to be just the right distance away from the door jamb: too far and the car won't lock, too close and it won't unlock. The door panel has to be removed and the actuator position needs to be inspected. If you suspect the actuator is siezed, it should be removed and tested (it can be manipulated by hand). If the internal microswitch is messed up, the only method I know of to DIY it is to replace the actuator with a known working unit and see if the door locks.
best, whit
