Results 1 to 10 of 20
Thread: Low compression in 1cyl of M30...
    Default Low compression in 1cyl of M30...
    I'm selling my E34 at the moment, it has too many things coming up due for repair/replacement, and I need the money. Plus, I've owned it for 3 years, and feel the need to try another car. I've found an E32 that's a bit rough around the edges, but going for a good price. It has few primer patches, a rattle in the front, and needs a general tidy up, but most significantly, has low compression in 1 cylinder. The owner bought it with the intention of doing it up, but never got around to it. It's a 735iL, and has the self-leveling LAD system replaced with conventional suspension.
    The car is driveable, but runs rough under 2000rpm. What can cause low compression in a cylinder? Is this easily fixable? Owner states it may have a cracked valve, but is not sure.
    This is of course all dependant on the sale of my car.
    Calgary AB Canada
    Quote Originally Posted by Dan in NZ
    Burnt valve, cracked valve, worn cam lobe (from loose oil sprayer bar banjo bolts).
    Anthony
    03/64 production
    Default To add to this list, bent valve ,seized valve and guide. broken rocker arm
    broken compression ring, piston with a hole in it, collapsed ring land, broken valve spring, scored cylinder wall, blown head gasket
    Quote Originally Posted by Anthony (M5 in Calgary)
    Melbourne, Australia
    Dan, your 21 year old logic amuses me!
    An enigma wrapped up in a contradiction!
    Then again you could just edit your post and remove this part....
    ...it has too many things coming up due for repair/replacement, and I need the money...
    ...and then everything would make sense!
    Quote Originally Posted by pundit
    I can get $4000 for my e34, this e32 is going for $800. I figure that I would spend $1000 on it, have a nice car, and be $2200 better off! What could go wrong!
    ....What could go wrong!
    With an $800.00 E32....?
    Okay guys start the list....
    Seriously spending a grand NZ (about $800.00 AUD or $600.00 USD) won't bring an E32 back from the brink. If money is a concern then you need to get European cars out of the equation because saving money and European cars is like I said before... screwing for virginity. You say that you can't afford to keep the E34 so you're planning on buying a half clapped out E32.... ??????? Well it's a slight improvement over the Audi Quattro but still not a money saving strategy old chum.
    Suspension/handling is fine, no shimmy or play. Transmission fluid is not burnt. LAD is removed.
    However there is a hole in the leather on the drivers seat, and a few primer patches on the paint... Only cosmetic, and could be fixed as funds permit. Front suspension rattles a bit, probably just loose strut nut or worn bushes.
    I figure the $1000 allocated for repairs would get the low compression in cyl 3 sorted out, valves adjusted, and all fluids I would change myself.
    Feb 2005
    Geneseo, Illinois
    Would low compression set off the cel?
    I don't know what a used M30 costs over there, but they're relatively inexpensive around here. If everything checks out okay, I wouldn't hesitate to buy it and R&R it.
    But get the 4 gees for your 525, first
    best, whit
    Wellington,New Zealand
    yes dan sell the 525 first.....4000?????Dont buy an old Euro,1000 bucks will prooly only take it apart and put it together again.....Buy good jappa keep changin the oil and coolant and the thing wont need anything else until it stops
    Gone but not forgotten
  1. No compression - wtf?
    Last Post: 06-23-2007, 12:53 PM
  2. low compression in 1 cylinder on e36 m3
    By ber55ber55 in forum 3 Series BMW
    Last Post: 08-11-2006, 05:10 PM
  3. M50 low compression in cyl 5
    By wilkie3 in forum 5 Series BMW
    Last Post: 08-06-2006, 01:35 PM
  4. lost compression
    By jking016 in forum 5 Series BMW
    Last Post: 02-28-2006, 06:27 PM
  5. Here's a piston with some compression.
    By Martin in Bellevue in forum 5 Series BMW
    Last Post: 10-12-2005, 05:29 PM
