Results 1 to 10 of 13
Thread: questions about changing automatic transmission fluid in 1990 525i
    Jul 2004
    Default questions about changing automatic transmission fluid in 1990 525i
    The auto-trans feels like it's slipping gears so I have heard that likely means low fluid or fuild change.
    I have the Bentley manual and it calls for "removing the ATF oil sump bolts", but the picture looks like the engine oil pan.
    1--Do I only take the ATF oil sump off?
    2--Are there any gaskets or filter I need to replace (purchase beforehand)?
    Thanks.
    1--Do I only take the ATF oil sump off? YES
    2--Are there any gaskets or filter I need to replace (purchase beforehand)? YES
    Jul 2004
    how would I know which gaskets and filters I need to purchase?
    Jun 2005
    Cleveland, OH
    Quote Originally Posted by notesguy
    Call BMA?
    I miss my e34
    LOL...about as helpful as me.
    Get the part numbers at realoem.com and look them up at BMA's web site.
    Jun 2005
    Cleveland, OH
    Come on Jeff... Patrick could tell him want parts he needs.....
    I miss my e34
    I know, but that would make things simple...people should see what they have and go from there...I learned a ton of info here from leads and not direct answers.
    Quote Originally Posted by dacoyote
    Jun 2005
    Cleveland, OH
    Simple things are good.....
    I miss my e34
    Kentucky
    Yes, you only take the sump off. There is a metal filter, a gasket for the sump and a o-ring that should all come as part of the filter kit you buy; if you do buy the kit.
    BMA has it as a kit.
  1. Automatic transmission fluid leaks
    By Al Gray in forum 5 Series BMW
    Last Post: 03-19-2007, 12:18 AM
  2. Replies: 3
    Last Post: 12-09-2006, 10:12 PM
  3. Replies: 5
    Last Post: 08-14-2006, 04:37 PM
  4. Replies: 5
    Last Post: 12-26-2005, 06:22 AM
