Simple green and water. No pressure washer... soak the area in SG and let it sit. Hose it out.
So after tightening all the P/S hoses and replacing all the clamps with adjustable ones, everything looks good. That is... except the engine bay. It's covered with grime and P/S fluid. What to use to clean it all out without eating the hoses and such?
Also use simple green.
Or what I also use a lot is kerosene, which is used here for the gas stoves/heaters.
Very good for cleaning. Cleaned all my intakes. throttle valves, engine room parts with kerosene and then used simple green and a little bit water or a dry cloth.
Diesel fuel is also good for washing and not as dangerous as normal gas.
But it smells like the hell and especially at your hands + clothes.
i stick a hose in the tank, take out about 1 liter and there you go, cheap cleaning+nasty smelling hands
