Originally Posted by
Scott H
Std offset on a set of E34 M5 t-stars is ET20 and ET22 for staggared set.
The fronts you are looking at are ET10 which means the wheel will stick out a bit more (10mm) in the wheel well.....the only thing you need to watch for is rubbing on the fender well, especially if you have the car lowered. You should have no problems...in fact even more clearance than usual against the strut tower.
The rears that you are looking at are ET19 which means the wheel will mount more towards the fender again, as the fronts do. Once again, if the car is lowered, you may find the tire rubbing the fender well a bit if you have the rear of the car loaded. Plenty of clearance inside against the shock.
Overall these wheels will fit.
