Results 1 to 10 of 14
Thread: differential fluid
    Nov 2004
    Default differential fluid
    which oil should i use for my differntial the number it has on the top right corner is 1 212 371 E, is it a limited slip?
    70w-90 synthetic
    Nov 2004
    is this a limited slip?
    whats the tag say, not the numbers on the casting
    Quote Originally Posted by ejhiggins
    What're the last 5 digits of the VIN? GFXXXXX
    best, whit
    Long Beach, CA
    You're reading the wrong numbers off the differential. There's a plate on it with the correct info.
    Nov 2004
    last five digits of the vin are 31878
    Nov 2004
    Coeur d Alene, ID
    Use Royal Purple or Red Line but figure out if you have a LSD or open it makes a difference..
    theDogger
    LSD uses the 140wt dope
    Quote Originally Posted by theDogger
    theDogger
    Nov 2004
    the last five of the vin# 31878
  1. Differential oil & brake fluid
    By russiankid in forum 5 Series BMW
    Last Post: 09-07-2008, 08:58 PM
  2. What differential fluid for 535iA?
    By sneekens in forum 5 Series BMW
    Last Post: 03-10-2008, 11:01 AM
  3. Differential fluid for 94 530ia
    By E34 530 in forum 5 Series BMW
    Last Post: 11-17-2007, 01:53 PM
  4. Fluid for the 6 speed gear box and differential
    By yaofeng in forum 5 Series BMW
    Last Post: 07-24-2006, 10:04 AM
  5. differential fluid
    By ejhiggins in forum 5 Series BMW
    Last Post: 01-15-2005, 05:34 PM
