i'm from malaysia and runs a e34 520i m50 non-vanos model - it has the air-cond option.
i noticed a couple of points:
1. rpm when the air-cond compressor kicks in is about 900 rpm - is it possible to get it down to 600 rpm ? is there a mechanical idle speed screw compensator to adjust to get the rpm down ? or is this setting controlled by ecu too ?
2. sometimes there is a tendency for the revs not to die down immediately when i take my foot off the accelerator - it's not like it takes seconds to die down but it kinds gets in the way when you need to change gears fast - i drive a manual.
3. the way the accelerator pedal is designed (hinged at the floor) is quite bad - gritty stuff like sands, peddles always get collected there. is there a better carpet design that prevents this from happening
4. i wonder if item (3) is somehow related to item #2 ?
i look fwd to your help here as i sort this out.
