Results 1 to 4 of 4
Thread: Thrust Arm bushings
    Default Thrust Arm bushings
    Which 750i Thrust Arm bushings are better? I have a choice of either Boge or Sachs. I will be using Lemforder Thrust Arms.
    Will Ollison
    1990 535i
    Default Hmmm, not sure which are better, but...
    if you're purchasing the arms and bushings seperate and plan on pressing them in, check to see if the cost is less than the Lemforders with pressed 750 bushings from BMA or Racing King (Bruno). Should be $85-$90 US. If you haven't already, it might be worthwhile to investigate. Lots of great info on thrust arm replacement floating around recently.
    Good luck,
    Dave M, new thrusty's and such.
    Quote Originally Posted by willobmw
    Will Ollison
    1990 535i
    Default Hey wait, aren't they related? (Boge/Sachs)
    Will Ollison
    1990 535i
    Missouri, USA
    Default Get the BMA or Racing King units for $90.....
    It saves you a LOT of hassle having them pressed in and you CANNOT beat that price, ready to install.
    I did mine recently and am thrilled with the results.
  1. X5 thrust arm bushings
    By Mr._Graybeard in forum 5 Series BMW
    Last Post: 07-22-2009, 11:22 AM
  2. Thrust arm bushings
    Last Post: 05-08-2006, 05:15 AM
  3. Thrust bushings
    By Felixdacat in forum 5 Series BMW
    Last Post: 04-27-2006, 12:11 PM
  4. Replacing thrust arms vs. thrust arm bushings
    Last Post: 05-09-2005, 08:08 AM
  5. Thrust arm bushings: M5 or 750
    By Edwin in forum 5 Series BMW
    Last Post: 05-28-2004, 08:23 PM
