Results 1 to 10 of 10
Thread: Reverse RealOEM lookup
    Feb 2005
    Penang, Malaysia
    Default Reverse RealOEM lookup
    is there a web site that shows a diagram of a particular part in relation to other parts if i know the part number - sort of opposite to the way realoem works ?
    This one works with cross references= it shows you in which other cars the same part number also has been installed.
    http://www.bmwtoolkit.com/index.php?...pper&Itemid=56
    Thanks Shogun, you've helped answer a nagging question about steering boxes.
    E34 535i LIMOUSINE M30 AMERICA
    32131138741 HYDRO STEERING BOX 19890900 to 19930200
    This will fit the 525im!!!!!!!
    Dave M
    Elm Grove Farm, NC
    You can do (almost) the same thing with realoem.com...but you have to make a couple of clicks.
    You have to get the part number, then go to the "search by part #" link, enter the part number in the box and click "search", then click "details for all" to see all of the cars that your part number was installed on.
    Confused??? Try it!!
    Bret.
    Is there any way to check online the old part numbers and then find out the up-to-date ones and from when these parts where available?
    Reason is that I bought 3 modules from German Ebay and seller says they are from a 1993 E32 740. If so, the GM would have the feature of all 3 windows one touch down.
    Or could someone check that out for me?
    GM: 61.35-8 356 095 6070. 109110
    The GM has a white dot on the back, do not know what that means
    RM: 61.35-1.379 741 6061.40x.01E
    LKM ECE L: 61.35-8 350 376 01 209,
    BMW 8 350 376
    085073051 0008177 01 Loewe
    Wellington,New Zealand
    in the same screen as above there is a line that show the new part no ,if there is one....
    61.35-8 356 095
    61.35-1.379 741
    61.35-8 350 376
    none of these number work on my etk
    "not installed on this model or not in part database"
    looking at 92 e 32 740 lhd auto
    Gone but not forgotten
    Paul,
    can you check also the parts on 1993 and early 1993 E32 740 LHD, European specification?
    I think the Loewe (maker) LKM was only in the last year(s). I found also a Lower LKM in my parts 750iL from 03/1994.
    Thanks a lot
    Nov 2004
    Quote Originally Posted by Rigmaster
    Bret.
    ditto...you can look up something by the part # only...and you can cross reference that part to all other BMW models that use it.
    If you already know the part #...you can click the link (see red arrows) shown in pic below and enter the 11 digit or 7 digit BMW part #...
    ...you will be sent to the page below if you click the link in pic above...and you can either enter the 11 or 7 digit BMW part #...search by a keyword (like mirror)...or click the link (red arrows) to cross reference part #s...
    ..if you click the "part reference link" in the pic above...you will go to this page where you can type in the BMW 11 or 7 digit part # and cross reference a part to see what other BMW models use that same part. You may also want to click the "EURO" box and use the "left hand" drive models for parts that don't appear in the USA diagrams but are available in Europe.
    All the above can be done from the online parts database...www.realoem.com/bmw
    Q
    95 525iT / 97 740iL
    Fine,
    but how can I find out what is the new part number of a part, if I have an old part with the old p/n only? See my above numbers which I found on parts which I bought.
    As you know, part number system has been changed from those old days.
    61358356095,superseded by 61358360104.others no luck....
  1. BMW defect code lookup tool
    Last Post: 08-17-2006, 09:12 PM
  2. Carfax Lookup request?
    By p_fern in forum 3 Series BMW
    Last Post: 05-31-2006, 08:27 AM
  3. E39 ETK lookup
    By AZ_Jason_S in forum 5 Series BMW
    Last Post: 10-13-2004, 10:28 AM
  4. Somewhat OT: GM part number reverse lookup?
    By Kevin in forum 5 Series BMW
    Last Post: 03-29-2004, 09:37 PM
  5. ETK lookup needed
    By rickm in forum 5 Series BMW
    Last Post: 03-03-2004, 07:10 PM
