Results 1 to 10 of 17
Thread: 535I engine missing after tune up
    Nov 2005
    Phoenix Az
    Default 535I engine missing after tune up
    1990 535I 150K miles - was running good no miss - slight off idle hesitation.
    Tune performed includes:
    Spark plugs - Bosch Platinium 2
    New BMW distributor Cap and rotor
    New rubber from air cleaner all the back to intake 2 large tubes replaced and small tube to Valve cover.(vaccum line reconnected)
    Adjusted Valves found 3 exhaust valves to be tight adjusted to .012
    Problem 1:
    Broke a inductive pickup off one of the distributor wires (3rd plug wire on distributor cap not sure what spark plug or if it goes to the ignition coil) - I have since glued this back together not sure what it is for?? Did not change the problem. - plus this could be the problem.
    Point of this post:
    Car runs much better except for a miss under hard aceleration mostly between 3 to 4 k RPM. This is intermittant and if I acelerate slowly does not occur.
    So any sugestions on:
    1 - Inductive pickup wire I broke - what it does??
    2 - Problem with my car
    3 -Bosch Platinuim 2 spark plugs??
    I have been trolling this site for a while so look forward to interacting with this group.
    Thanks in advance!!!
    The inductive pickup goes over the spark plug wire to cylinder #6. This "sensor" directs the dme to split injector duty between 2 banks of 3 each. The 1.3 motronic on the 535's allows for 3 injectors to fire at a time, instead of earlier versions firing all 6 injectors together. This prolly won't cause a noticeable problem in driving.
    Get the correct Bosch silber spark plugs for the m30. M30's don't like platinum plugs. This is likely yer problem.
    erased due to slander
    Default Agree.....start with the plugs
    always stick with specified plugs on the M30
    Quote Originally Posted by Martin in Bellevue
    Quote Originally Posted by Scott H
    Oh great, another DITTO post.
    Damn good help there, scotty.
    Default Martin you're gonna get me banned again!!!
    "You have been banned for the following reason:
    needs a valium - and to leave work
    Date the ban will be lifted: 12-01-2005"
    Just b/c we're not all playing with fuel management and ignition stuff doesn't me we don't have something to offer.
    You did seem to run out of midol today.
    Bosch W8LCR
    best, whit
    Hockinson, Washington
    Its always nice to hear more than one opinion, even if they are the same. The PO installed platinum plugs in my car, and now with two people saying that the m30 doesnt like them, i will buy regular bocsh plugs.
    Nov 2005
    Phoenix Az
    Default Bosch W8LCR - is what I took out..
    Yes this will be my first step -- Thanks all
    Quote Originally Posted by lowell
    Bosch W8LCR
    best, whit
    Nov 2005
    Phoenix Az
    Thanks - for info on inductive pickup - plus - replace your plugs again - Will do ASAP
  1. missing relay?535i
    By jjdickm in forum 5 Series BMW
    Last Post: 04-02-2008, 01:46 AM
  2. First tune up
    By dcbimmer in forum 5 Series BMW
    Last Post: 09-04-2007, 04:24 PM
  3. 535i engine build help.
    Last Post: 07-04-2007, 10:47 PM
  4. Tune up help
    By rundown11 in forum 5 Series BMW
    Last Post: 05-19-2006, 12:47 AM
  5. 89' 535 missing bad till engine warms.
    By Jer in forum 5 Series BMW
    Last Post: 11-20-2004, 07:49 PM
