Originally Posted by
George M
Hi Allan,
Can be done two ways really...what Martin did which is lift the motor up which I did partially as well with the exception that I dropped the engine cradle X-mbr because it was over the winter and I had my suspension off for rebuild anyway. Removing the X-mbr is more work but in some ways easier if that makes any sense :-) Brief explanation....remove all the stuff that Martin suggested...a good time to change the engine mounts as well. Push the motor up from underneath about 2 inches or as high as it will go. Shim the engine mounts up with small blocks of wood...this can be done with or without the puck style mounts present. Visualize all the stuff effected...I loosened the trans mount bolts for example and exhaust hanger mount prior to pushing the motor up. A tip is...the CG of the M-30 is not symmetric about the X-car centerline...put a generous block of wood under th "left side" of the aluminum oil pan and push up with a floor jack for equivalent raising of the engine from each engine mount. I suggest you first try it as Martin did....loosen the pan....drop it down onto the engine X-mbr and then stick your hand in between the pan and bottom of the engine block and remove the oil pick up from the oil pump which hits on the baffle inside the pan if trying to remove the pan with the pick up intact. This technique does take some dexterity but probably the best way to get the pan off and have access to the oil pump for removal. As you can probably surmise, this is not one of the more pleasant jobs to perform on these cars...a bit messy and awkward.
If you get into the job and get stuck, either post or send me an e-mail.
HTH,
George
