Results 1 to 4 of 4
Thread: ignition switch install
    Jan 2005
    Default ignition switch install
    Purchased a new ignition switch. The one in the car is so worn the key comes out while in gear.
    Following the Bentley guide I used a piece of hard wire, one of those dealer key rings straightened out, turn the ignition to the 60 degree position, inserted the wire and .... the switch won't come out?
    What am I missing here?
    Default You also have to kind of push it at an
    angle to the outside of the switch ..
    Quote Originally Posted by peterllo
    Use a heavy duty paperclip, bent ~15 degrees at a point about ~1/4" from the tip. Insert the paperclip to a depth of about an inch, with the bent tip facing away from the centerline of the ignition lock. As depicted previously, the key must be at the ~60 degree position for the internal holes to line up and for the paperclip to work.
    Boston & Attleboro MA
    To get an idea of what to do and how it works, you can put the key in the new one and put the tool/clip/wire in that one to see what movements raise the clip/bar thingy.
    It was a little of a PITA to get mine out, and remember installition is the same steps.
    Current
    2008 M5 6 Spd
    2000 Z3 2.8 5 Spd MSport
    2012 X5 35d Sport
    1995 540i 6 Spd
    1992 535i 5 Spd
    Former
    1995 530iA
    1986 635CSI 5 Spd
    2011 X3 2.8 MSport
  1. My ignition switch will only turn a 1/4 of the way
    By WILLIETOPZ in forum 5 Series BMW
    Last Post: 05-11-2007, 05:59 AM
  2. Ignition switch/key trouble
    By gale in forum 5 Series BMW
    Last Post: 03-20-2007, 11:15 PM
  3. Ignition switch/lock?
    By K_Po_Uno in forum 5 Series BMW
    Last Post: 03-12-2005, 12:45 AM
  4. Ignition Install
    By mtcoolguy in forum 3 Series BMW
    Last Post: 09-23-2004, 06:26 PM
  5. ignition switch, $550 later (ouch)
    By kjbcpa in forum 5 Series BMW
    Last Post: 03-25-2004, 12:39 PM
