My left low-beam (outer) headlight went out a few days ago, so i decided to take the bulb out to see if it was really burnt out. It was broken. My brother suggested that the water inside the headlight spalshed up on the hot bulb and caused thermal shockwhich broke the bulb. As you can see, there is quite alot of water in the headlight:
My question is, where can i buy a new headlight lens and how would i install it? I would also like to hear about other options (if there are any).
Now if only e34s had sealed beam headlights, then i could just go to the store and by one off the shelf for $6; thats certainly a plus for the e28
Thank you, i might just place a bid on those euro lights.
the german complete have the metal reflector on the wrong side of the bulb if used in the US market.
Originally Posted by shogun
Good point, does anyone have any idea what a lens might cost at the dealer?Originally Posted by 632 Regal
Here's a good link http://home.comcast.net/%7Ewinstonfo...illremoval.htm
Best prices I've seen are at Bavauto.com and BimmerSpecialist.com
Not to hijack this thread, but does anyone know of a place that sells just the lenses for the fogs ?
cheap preferred
Shucks, the E30/E28/24/23/21/12 sealed beams suck terribly, man. I'd take ellipsoids over them any day.
It may be easier to just replace the entire bucket assembly, I'm not sure. The adjustment screws tend to fuse/rust, plastic parts crack and shatter.
best, whit
The entire bucket assembly costs significantly more than just a lens, and since this is on my parent's dollar i would like to find the most cost effective solution.
