Results 1 to 4 of 4
Thread: Headlight out but not LKM or bulb
    Sep 2004
    Default Headlight out but not LKM or bulb
    I tested my LKM by using another one in my car, 95 540, and the headlight was still out. So it's doesn't look to be the bulb or LKM. Is there anything I can check before taking it to my mechanic?
    Communist-wealth of Massachusetts
    Quote Originally Posted by ra_pro
    I assume that you tested the burned out bulb on the other side or another car to confirm it is dead? And a new bulb in place of the burned out one also? Did you check the fuse? The headlights are on seperate circuits for obvious reasons.
    Good Luck,
    Rory
    <Insert list of modifcations or clever saying here>
    Yorktown, VA
    Check out the male connector on the harness at the headlight. One of the wires inside the connector on my car had burned through and shorted out. You couldn't see it unless looking very carefully.
    zmuff--1989 535i 5-speed--17" E39 Style 32's--JC chip--UUC Short Shift--
    --Racing Dynamics Springs & Sways--Bilsteins--Yorktown, VA
    Hockinson, Washington
    My fog light currently has a problem with the male connector on the light as well. The wire its frayed on mine, i would check this if i were you.
  1. copper ring that holds headlight bulb in
    By bbig119 in forum 5 Series BMW
    Last Post: 04-05-2007, 07:38 AM
  2. Replies: 11
    Last Post: 10-04-2006, 06:35 AM
  3. Replies: 0
    Last Post: 06-27-2006, 01:00 PM
  4. How to replace bulb in the headlight switch?
    By Mario in forum 5 Series BMW
    Last Post: 08-28-2004, 10:26 AM
  5. Replies: 7
    Last Post: 03-10-2004, 09:30 PM
