It's an opening for the interior temperature sensor - blocking it is not a good idea.Originally Posted by jaylebo
That little one, about the size of a fingernail, between two of the HVAC dials. What is it?
My car's aftermarket wood kit covers mine. Is that a problem?
What you suppose the consequences are of blocking it? My HVAC's never worked quite right. I wonder if this is why.Originally Posted by Interceptor
Since the wood kit was installed by a previous owner, I didn't even know there was a vent there until I saw the pic of your new steering wheel, Interceptor! The vent's clearly visible in that pic.
Before I go cutting up the wood kit, I'd like to know what I'm missing by having the vent blocked.
By covering that vent you are blocking air flow so the temperature sensor cannot precisely determine the interior temperature which may lead to funny heating/cooling behaviour - for example overheating or overcooling, no matter what temp you set on the dials.Originally Posted by jaylebo
Happy slicing I hope you get your HVAC back to normalOriginally Posted by jaylebo
I believe the thermostats are over-rided when the drivers temperature dial is all the way in either direction, so you would probably have to do that if you wanted it to function reliably with a blocked temperature sensor.
