Results 1 to 10 of 12
Thread: EWS Dummy
    Default EWS Dummy
    I am trying to determine if my E34 is equipped with EWS or not.
    5-speed auto left-hand drive euro 525iSE build date 12/94, VIN: WBAHD61050GK60634
    Hope the attached images might provide some clue to those who are not EWS dummies like myself.
    DME Bosch sticker image to follow.
    Cheers from Taiwan for any insight ...
    Jason
    Default EWS Dummy (cont'd)
    And the Bosch sticker ...
    Default EWS Dummy (still stumped)
    DME = Part 12141427273 (Bosch M3.3.1 ECU) (realoem.com)
    Dummy EWS ignition ring cover = Part 61358368340 (realoem.com)
    As per the photo, the stock chip is:
    1 267 358 715
    0 261 200 413
    Everything except for the stock chip software version leads me to believe I do not have EWS-II ...
    Nov 2004
    Split, Croatia
    Quote Originally Posted by jasonechols
    1 267 358 715
    0 261 200 413
    It looks like your car doesn't have EWS-II but it could have been added as an option (hence the dummy ring). EWS-II came as a standard option in late '95.
    Default No, EWS II came along as of 1/95 as you can
    see here on the e34 but he would have EWS I which doesn't have a transponder key so the dummy would have been in place of the inductive loop on the ignition. Since the transponder key came along shortly after his car was produced that could account for the dummy
    Quote Originally Posted by Interceptor
    Default This is what the ews I would consist of
    Nov 2004
    Split, Croatia
    Once again, great info from you, Bill. Thanks!
    Toronto, CANADA
    Jason
    That sure is odd. Your grey label DME is the color of the EWS DME, you have the EWS software label on the chip ( 1 267 368 715) but it doesn't appear like you really have EWS. It would be interesting to read that chip and see what's in it.
    (Jason ordered a chip from me, I sent the EWS chip, and his car does not start)
    MarkD
    Nov 2004
    Split, Croatia
    Quote Originally Posted by MarkD
    MarkD
    Your page says that early '95 cars don't have EWS-II and that late ones do - if Bill R is right (isn't he always?) all MY 1995 cars have it. Maybe that's the problem?
    Toronto, CANADA
    EWS-II was introduced in 12/94. (so late 95 cars have it)
    A car made in Sept 94 would be called a 1995 model here.
    He has an EWS DME (grey) and the chip has the EWS-II software label.
    MarkD
  1. uk source for dummy chain tensioner
    By sal_park in forum 5 Series BMW
    Last Post: 01-02-2010, 08:37 AM
  2. Brake Fluid dummy light on dash
    By nealf in forum 5 Series BMW
    Last Post: 01-24-2007, 06:40 PM
  3. Replies: 0
    Last Post: 07-19-2005, 08:47 AM
