Results 1 to 10 of 15
Thread: Shudder during reverse
    Melbourne, Australia
    Default Shudder during reverse
    Hi Bimmer nuts
    this is my first post, but I check out the site at least once a day - I'm hooked bad. For the last year I have been the proud owner of a graphite grey 1993 540i auto, with 175,00 (about 110,00 miles) kilometres on the clock, with fake throwing star wheels - I am the fourth owner and the car is terrific and practically rockets down the road.
    Every thing is fine and I read and use all your great tips and terrific suggestions - from Shogun's reset, Winfred's sober insights and Javier's electrical wizardry through to choice of Mobil 1, which I change evert 3 months.
    Here's my problem: just recently, when the car was cold or cool and I selected reverse it would shudder and lack power. This is especially prominent when reversing up a slope. When warmed up it seems fine and reverse has no shudders and it has power - other than that, all forward gears seem to act as they should.
    Is this the early sign of something grim? Will a change of oil fix it, as I don't think that its every been changed. Is it a connection or linkage problem?
    I really would appreciate your help and advice over here in far away Australia.
    May 2005
    central coast nsw au
    hey ken, you should post more mate. theres heaps of us over here. I think we have the same car down to the colour. Does reverse take a second or two to engage?
    Aug 2004
    Dubai
    u seem to have transmission problem ... old transmissions does this, usually as mattyb said, your tranny should engage after 1 sec approximately and the car should lift up a bit from behind, now if ur tranny is not working proparly then they transmission fluid pressure is not making the clutches shift the torque proparly causing the clutches to slip and engage frequently. as a results u will feel the shuddering. I don't know much about the fluid change for your tranny. maybe some other guys would reply and tell you. also you can search in the forum for tranny problems on M60 engines.
    good luck
    I would try by changing the trans filter and the fluid that comes out with that job only and see if that fixes the problem, the longer you wait the more damage you are causing. That trans takes specific fluid too.
    Aug 2004
    Dubai
    thats true ... by the way ... this tranny rarly needs the fluid changed, right? but how rarly is it? 130K ? whats the oil type? I know its synth. oil but what type??
    takes the special shell or esso trans juice that costs like 20 bux a quart, thats why people are experimenting with generic stuff.
    Aug 2005
    Iowa, USA
    If you figure out what it is or how to fix it, let me know. mine does it too (more when engine is warm tho)
    Quote Originally Posted by mattyb
    Thanks Mattyb
    you got it - one to two seconds to engage reverse. It a great car and I want to keep it in tip top condition and don't want to fork out too much money if it's not needed.
    Any advice will be great.
    Quote Originally Posted by mzarifkar
    Thanks go to all you guys
    I am having it checked over tomorrow and will let you know - I think that I will start with the oil and filter change as you all suggest.
    Quote Originally Posted by Ken in Australia
    Ken,
    it might also be your rear brakes binding a little after being left at night with the handbrake on.
    Greg
    E30 318iS & BMW K1200LT
  1. wheel shudder
    By Paul in NZ in forum 5 Series BMW
    Last Post: 02-25-2008, 04:13 PM
  2. 540i Engine Shudder/Vibrations
    By chiefcorey in forum 5 Series BMW
    Last Post: 06-27-2007, 08:03 PM
  3. Shudder on shut-off
    By Tom Bombadil in forum 5 Series BMW
    Last Post: 07-08-2006, 04:25 PM
  4. Shudder/Grinding
    Last Post: 02-19-2006, 01:10 PM
  5. Auto Shudder
    By Watto in forum 5 Series BMW
    Last Post: 05-24-2004, 11:51 AM
