Results 1 to 7 of 7
Thread: 1992 e34 525 ... need help with vanity lights
    Nov 2005
    Ann Arbor, MI
    Default 1992 e34 525 ... need help with vanity lights
    The driver's side vanity light (the one above the sun visor) has been out for a while. The passenger vanity light started flickering about a week ago and then totally went dead 2 days ago. I bought new bulbs for both, thinking that may have been the problem. But after installing the bulbs tonight, both vanity lights are still out.
    Does anyone know what the problem could be? I'm assuming it's in the wiring somewhere, but I don't even really know where to check, or what to check for. Any help would be appreciated.
    I know vanity lights are a small thing, but I like to keep everything working properly on my baby!
    Hockinson, Washington
    I think i know the answer to your problem. I had this same problem for awhile, until i discovered that those lights do not always turn on when you slide the mirror open. I cant remember exactly, but i think that the head lights must either be on or have been on while you have been in the car in order for the vanity lights above the mirrors to work. I thought it was very strange myself...i hope this helps you!
    Default If your sunroof switch is being lighted, ...
    power to the circuits should be OK (best way to confirm is to test bulb light contacts, as one of them should have 12V to ground when lights on). Then ground path trough the sun visor switches should be checked. If I recall properly, it is a combination of a contact in the parking socket for the sun visor prong, and a switch in the mirror sliding cover. Check those tricky ground switches as they may be dirty. Hard to reach, I guess, have never tried.
    Javier
    i'd agree with a bad ground issue.
    Quote Originally Posted by Javier
    Javier
    Long Beach, CA
    On mine the headlights have to be on and the mirrors open to work.
    Wellington,New Zealand
    make sure the visors are clicked into the holding clips and that the contacts are lined up.If you look closely at the visor there is a "bush" that clips into the holder in the car.You can see a wire in each make sure they are aligned
    Gone but not forgotten
    Nov 2005
    Ann Arbor, MI
    Thanks for all the responses, guys. I'll try everything tonight. When I was testing, I don't think I had my headlights on...so hopefully that's all it is. But if that doesn't work, I'll check the grounds.
  1. Vanity Plate Gallery:
    By artguy in forum 5 Series BMW
    Last Post: 09-15-2007, 03:09 AM
  2. vanity light switch location/function ?
    By cobb535 in forum 5 Series BMW
    Last Post: 07-04-2007, 10:07 AM
  3. stupid vanity plates
    By BMW4ever in forum 5 Series BMW
    Last Post: 04-02-2007, 12:06 PM
  4. Interior Lights Don't Work (1992 525 Wagon)
    By imnprsd in forum 5 Series BMW
    Last Post: 05-29-2006, 11:11 PM
  5. Replacing Lights In Cluster - 1992 535ia
    By Jimmy535i in forum 5 Series BMW
    Last Post: 12-16-2004, 10:30 AM
