Results 1 to 8 of 8
Thread: M60 Brake Fluid bottle.... need help w/ clutch issue
    PA
    Default M60 Brake Fluid bottle.... need help w/ clutch issue
    Is it supposed to be "empty". My sister said she popped the hood (clutch issues). I don't know, she said the "brake fluid" thing looked more like a "tube". I couldn't understand if it was a fill tube or if that is the actual brake fluid resevoir. Regardless, the brake fluid "tube" is empty. This indicates to me either a leak somewhere or maybe a mechanic did a horrible job of bleeding the brakes at some point.
    So now, assuming its out of fluid, do i just top it off, or do i need to bleed this whole thing?
    Mar 2004
    Refill and pump clutch pedal, it will probably self bleed. Then you can drive it home and look for the leak.
    EDIT: Looks like M60 clutch has it's own reservoir. Tough to share a reservoir if brake MC is behind LF headlight. Also looks like clutch MC won't self bleed....there a big loop in the tubing according to ETK.
    Paul Shovestul
    women hmphfffff...can she snap and email a picture of these new terms for old parts for you? LOL maybe the mechanic removed the container and it IS just a tube there or something....never can tell.
    PA
    Jeff can u post pic of your engine bay?
    Wellington,New Zealand
    jeffs car is an auto....
    Gone but not forgotten
    not auto....slush box
    Quote Originally Posted by Paul in NZ
    PA
    Alright well the post bumping was appreciated, but i really need to know how to check the clutch fluid level on an m60 3.0. Sister can't drive it to school.
    fwiw here a pic of my m30..... you can see the clutch resevoir just "above" the expansion tank...hopefully hers is similar
    man i gotta clean that sob
  1. Brake Fluid Light Issue
    By BIGRED in forum 5 Series BMW
    Last Post: 04-21-2008, 12:15 PM
  2. clutch pedal issue
    By attack eagle in forum 5 Series BMW
    Last Post: 12-07-2007, 09:06 PM
  3. help please on possible clutch issue
    By kick7ca in forum 5 Series BMW
    Last Post: 09-27-2004, 06:04 PM
  4. Ac Compresser Clutch Issue..
    By Boggie1688 in forum 5 Series BMW
    Last Post: 06-16-2004, 02:33 PM
